Author Topic: neutral light stays on  (Read 767 times)
Offline the technological J
  • deliciouso!
« on: June 17, 2009, 09:25:55 AM »
im looking into a 79 750 that the neutral light stays on is this a sign of any other problems?
the bike has had some other work done to it like frame painted and new tank paint ... seems like it might be a deal if thats not a problem..hes only asking 1k
94 ST1100..Gone
72 750 K2 Stay tuned!
Offline ken736cc
  • When the cops pull me over, I usually let them off with just a warning.
Re: neutral light stays on
« Reply #1 on: June 17, 2009, 10:16:53 AM »
A short circuit to ground anywhere in the neutral light wiring can cause the light to stay on. Disconnect the wire from the switch ( on the bottom of the engine). If the light goes out, then the switch is bad.
Hope this helps.
K0 sandcast(in process of restoration), K0 diecast, K0 cafe racer
BMW R69S daily rider, 71SL350, 71 SL100, 63 SS50
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #2 on: June 17, 2009, 10:20:23 AM »
Should be an easy fix.  Definitly not a deal breaker if you like the looks and operation of the machine.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Chippy569
« Reply #3 on: June 17, 2009, 11:18:42 AM »
i assume the transmission is actually shifting, correct?
