Author Topic: Keihin carb question  (Read 1650 times)
dillwad
« on: November 10, 2005, 08:04:52 PM »
Ok so i got this 77 550 ran like crap cleaned the carbs out lots of junk in them
there is this part  i think it is called the slow jet   http://www.factorypro.com/images/jets/keihin,pj,series22.jpg
My question is this if anyone knows  my past expereince with carbs tells me i should have a hole thru the center of this
All four of mine do not     SO does it have a hole thur it  It is a slow jet and hould mter some how  but dang i  dont see how it can
thanks for your help
Offline mick750F
Re: Keihin carb question
« Reply #1 on: November 10, 2005, 08:17:53 PM »
   I'm not familiar with your carbs and your link doesn't seem to work but being a jet yes there should be a hole. They must be clogged. Have you had them out of the carbs? You need to get in there with carb cleaner and a thin strand of copper wire. It's better to soak them before trying to clean them. Compressed air will help too.
Mike
Glosta, MA
« Reply #2 on: November 10, 2005, 10:23:18 PM »
The bike in the avatar looks like Rob Lloyd's bike.
The slow jets should have a hole in them.  It's about a .016 inch restrictor near the base of it.  Try not to modify the hole dimensions.
dillwad
« Reply #3 on: November 11, 2005, 05:57:42 AM »
Mike
Yeah The bike is not mine but it is my insperation for the 550 i just picked up
The carbs are off and soaking   I just thought it strange all four would be clogged  so i started to question if i should be siting out in the cold with a piece of wire  trying to work it thru the brass  you know
Any way thanks for the reply I now know what i have to do today
And if the owner of my avatar wants me to remove it i will with no prblems I dont mean to imply it is mine
It is just a beautiful bike
brockj
« Reply #4 on: November 11, 2005, 06:29:37 AM »
When I went through the carbs on my 78 550 3 of the 4 were plugged.  I had soaked them twice before trying to blow air and nothing worked.  Eventually I took a piece of wire and pulled out a single strand of copper wire from it and worked them clean, going back and forth with wire and carb cleaner, tedious process but worked very well.  I pulled the slow jets out on mine before doing it.
cd811
« Reply #5 on: November 11, 2005, 11:59:00 AM »
the slow jet are one of the first things to go wrong(clog) on all of these types of carbs. no matter of brand , bike or cc. lawnmowers to harleys ;D
dillwad
« Reply #6 on: November 11, 2005, 05:09:19 PM »
Yep so true all 4 of mine were monked up I cleaned them today put all the carbs back together.
 shot a little strater fluid and that baby fired right up idled so smooth ran like crazy I can not believe how great this 550 runs
I own a FJ 1100  and man this little honda was sweet  fixed the front brake , it was hung  alot of corrosion  pumped  the brak and ran the piston out cleaned  pushed it back in  bleed the brakes   what a deal  a 76 550f and a 77 550 f 500 busk this tool had no clue how to wok on a bike .
At any rate thanks for the help i hope to contribute  a few things here
I  will post some pics of the bike still looks like A$$   but hey its only been a week
clubman bars on order
later
