Author Topic: Need help with 650 carbs!!!!  (Read 1609 times)
Offline krazyk
« on: June 18, 2009, 06:27:34 PM »
I have a 79 CB650 that I M trying to grt back on road. I broke the plastic choke tab while I was removing them. I took them to  a local guy to rebuild them. He has them for 4 weeks and has not done anything to them. Picked up a set of 81's the rubber T's are dry rotted where can I find replacements. Also going to rebuild 81's any advice. Also would be interested i buying a set of carbs ready to  install.
Offline cb650
Re: Need help with 650 carbs!!!!
« Reply #1 on: June 18, 2009, 06:35:03 PM »
The 81 carbs wont fit on the 79.  spacing on the heads are diff.
Where you at?
Offline krazyk
« Reply #2 on: June 18, 2009, 07:03:47 PM »
I M in Lenoir NC I M open to all options the problem with the 79's is the plastic choke lever broke when I removed them. do not know what I M going to do.
Offline razor02097
  • Not a fool, just an
  • Yes its a Honda You got an F'in problem with that?
« Reply #3 on: June 18, 2009, 07:15:46 PM »
woah slow down there partner...  Glad to have you aboard!
First off photos would help.  Please explain exactally what broke.  If its the choke knob or cable then it can be replaced easily.  Below is a diagram name the part that broke.
« Last Edit: June 18, 2009, 07:19:08 PM by razor02097 »
Project Rina
That is an inconceivably egregious transgression against my rudimentary concordance of socially shunned individuals.
Offline krazyk
« Reply #4 on: June 18, 2009, 07:51:05 PM »
The plastic lever that choke cable hooks to. I looked at the photo and dose not show choke linkage. On pg 14 of the the fuel section of the 79 shop manual you can see the piece I M talking about second pic he has his thumb on it. Do not know what correct name is.
Offline cb650
« Reply #5 on: June 18, 2009, 08:04:33 PM »
They seem to break frequently although I havent had one break.
Kit did but I cant remember her fix.   The choke part off the 81 carbs is steel but dont know if it will interchange.
Offline Hush
« Reply #6 on: June 18, 2009, 08:39:23 PM »
Mine's a 79 and it's steel too so there seems to be some variation.
I wonder if the 81 choke plate would interchange to the 79's?
You can still ride your bike without the choke, it will just hate you a bit longer as it warms up. :D
Sounds like you need some hands on help, remaking carbs is a big call Krazyk.
There are so many different little springs and such that if you stuff it up you'll do good job.
Re sell the 81 carbs and buy the bit you really need for your 79, I got a full rack of carbs for $50 and here in New Zealand parts are very very expensive.
« Last Edit: June 18, 2009, 08:44:37 PM by Hush »
Offline krazyk
« Reply #7 on: June 19, 2009, 02:19:24 AM »
I M sure I M not the first one this has happened to. What are my options for carb 79-80 will any of the 750's work. Have a friend who messes with SOHC 750's. I  was wondering whether the one off 81's would work. There must B a Carb Master out there that would have the answer just have to find them. So this question has now turned into a quest to find the all mighty OZ of carbs.
Offline jeepster
« Reply #8 on: June 19, 2009, 04:00:19 AM »
If the 81 carbs fit, you should definitely go with those as they are CV and much easier to work on. Post a pic of the the part that broke first though, there is a lot of creative folks on this board. Might be an easy fix.
"An ounce of prevention is worth more if you break it up into nickel bags."
Offline razor02097
« Reply #9 on: June 19, 2009, 04:49:51 AM »
My 1980 650 is steel too   ???
If I'm not mistaken The CV carbs fit on the CV head.  Its best to stick with the stock setup me thinks...
Maybe replace with a steel piece.
Project Rina
Offline cb650
« Reply #10 on: June 19, 2009, 05:13:18 AM »
I am very interested in why some are steel in the 79/80 carbs.  I have 3 sets of them and they are all plastic.  Soos put 750 carbs on his off a 74 I think.  Havent heard from him though. He was supposed to come by last week.
Offline MJL
  • Don't listen to me, I'm no
« Reply #11 on: June 19, 2009, 05:36:06 AM »
The ones between the carbs? Those are vents, and I haven't had any on my bike since I got it in '00.  No problem.
Offline fishhead
  • Why don't you go.....Well, you know the rest.....
« Reply #12 on: June 19, 2009, 05:48:38 AM »
All of the CB 650 PD carbs I have seen have the plastic choke actuator thing. When the choke rods are removed fron the carbs, the plastic choke actuator thing stays on the L/S inner carb and does not remove with the rod like on the 550/750 PD carbs. I dont know if the 550/70 metal actuator thing can be used on the 650's, but I dont think it can be. (the 650 carbs are probably thicker where the plastic actuator thing mounts) although I havent tried it.
Quote from:  Vanna White
Photobucket slide show (Fishhead Big Brakes)
http://s111.photobucket.com/albums/n130/dgfischer/Fishhead%20Big%20BRakes/?albumview=slideshow
Offline Hush
« Reply #13 on: June 19, 2009, 06:14:44 PM »
My choke round thing is def metal, I remember someone telling me that 750 carbs would fit our 650's and were easier to get parts for and to work on, could have been Soos.
As 650's were only produced for 4 years you'd wonder why they changed so many parts eh!
CV's will not fit our heads, not without massive retrofitting so I'd give that a miss. :)
Offline krazyk
« Reply #14 on: June 19, 2009, 06:31:33 PM »
So are the 74 750 PD carbs work on our 79/80 650's
Offline MikeB
« Reply #15 on: June 19, 2009, 07:55:16 PM »
Hello krazyk
you will find alot of helpfull info around here
read Soos  project thread
http://forums.sohc4.net/index.php?topic=33209.0
think he had a set off a 750 on his 79 650 then went to a set off a 84? ninja that he made work
he said the would fit the cv heads better but he made them work, if that is the case
the set you got off the 81 could be made to work
think he just used the rubber intake off of the ninja but not sure, it is in his thread somewhere
allot of info in there for the 650s
Mike
P.S  Just found this in the registry of 650 owners
Quote from: griff6-5-zero on February 26, 2009, 02:32:41 pm
Will these CV carbs switch out with the Mechanical carbs on a 80 cb650..... Thanks
They will... but you gotta make 'em work to an extent.
3 things needed really.
1 the '81/82 cb650 CV carbs
2 '84 through '91(?92) carb isolators off of a kawasaki ninja.
3 the appropriate throtthe cables for the '81/'82 cb650 CV carbs.
You don't end up with picture perfect alignment.... but it works.
I have a post on fitting '84 kawa ninja(600cc) carbs on my '79cb650 bike.
The same instillation procedures apply for the CV cb650 carbs on a non CV cb650 head with those isolators.
Basically put the isolators on the head, get carbs in place, and tip the intake side down, and the motor side of the carbs up, so they rest in the isolators(not a perfect alignment)
then as rotating upwards, pull them on.
http://forums.sohc4.net/index.php?topic=40287.0
A little more difficult than stocker carbs with old carb isolators though.
If that gives you an idea.....
« Last Edit: June 19, 2009, 08:08:49 PM by MikeB »
