Author Topic: 74 cb200 blinker problem  (Read 3330 times)
jeepnut
« on: June 19, 2009, 11:49:32 AM »
i have a 1974 honda cb 200 .The blinkers come on but wont flash  have looked for a relay with no luck  any sugestions ? thanks  jeepnut
Offline my78k
Re: 74 cb200 blinker problem
« Reply #1 on: June 19, 2009, 11:51:47 AM »
Lots of guys swear by newer electronic flashers. Biggest problem with these older flashers is not enough juice to trip the relay.
Is the battery fully charged? Are the connectors cleaned etc etc
Dennis
jeepnut
« Reply #2 on: June 19, 2009, 12:00:12 PM »
Dennis
do you know how much juice i should be getting at the blinker and where to find the relay?  or what it looks like on these old bikes, thanks
Offline kirkn
« Reply #3 on: June 19, 2009, 12:45:09 PM »
On my '74 CB200, the blinker relay is under the seat, right behind the battery box, near the starter solenoid.
Mine, too, needs an absolutely top-notch battery to blink properly.  Run the starter for a bit (if the engine doesn't happen to light off right away) and they won't flash until the battery is charged up a bit (ie, high revs...)
Generally, it happens due to 35 year old connections, especially ground connections.
All of the current for the blinker bulbs flows thru the relay first, before going up to the switch and out to the bulbs.  So, poor connections, etc. will serve to limit the amount of overall current flow to the point where the old, original relay will not cycle, even though enough current is flowing to 'adequately' light the bulbs.
Clean ALL the connections (always a good idea, but time consuming) and/or get a relay that requires slightly less current to cycle.
Occasionally, bulbs of a lower wattage will get accidentally substituted along the way, which draw less current, making the problem worse.
Kirk
Offline my78k
« Reply #4 on: June 19, 2009, 12:51:09 PM »
Yeah what he said...lol
Offline Laminar
  • Retsam
« Reply #5 on: June 19, 2009, 01:38:35 PM »
I'll echo the same thing - my CB200's blinkers didn't tend to work under 2 or 3000 RPM if I remember correctly, and sometimes at 7000rpm they'd be flickering furiously.
jeepnut
« Reply #6 on: June 19, 2009, 02:32:00 PM »
Thanks everyone I found it! Hideing behind the soloniod blinkers just became a secondary problem
  brother just kicked the kick start off. Anyone have a kickstart shaft for sale !! LOL. Thanks again    jeepnut
