Author Topic: Project Streetfighter ('72 CB750) UPDATED PICS!  (Read 25877 times)
Offline captaincrash80
  • I better build something before I'm no longer considered a
  • Member #4842
Re: Project Streetfighter ('72 CB750)
« Reply #50 on: April 21, 2010, 07:57:35 PM »
Ok, so I'm finally back (again  ;)). After lots of moving, working and misc life junk I'm finally able to start on the bike yet again. I have it rolling and running, just waiting on some funds to buy parts (brakes, etc). And now since I know how much you enjoy them, a video for you of the bike running for the first time in over a year   :D
[youtube=425,350]kt7JCBNX7pc[/youtube]
One problem that I'm running into right now though is my kickstand. With the drag pipes I can't raise it and it seems very unstable. Any alternatives that would take minimum modification? I don't have access to a welder :(
Offline Ecosse
  • Member #4139
    • My 550 walk around video
« Reply #51 on: April 21, 2010, 11:49:49 PM »
congrats!!
 8)
1974 CB550K
                                  Your 1%er name
  • Member #4842
« Reply #52 on: April 23, 2010, 11:16:49 AM »
Thanks Ecosse, the timing issues were killin me  :P
« Reply #53 on: April 23, 2010, 11:43:39 AM »
Well done on the build - do you have a photo of the complete bike side on? Im curious to see how your carbs look on the bike...great job on cleaning them.
cheers
Andy
  • Member #4842
« Reply #54 on: April 23, 2010, 01:50:11 PM »
I'll get some photos up tonight. The bike's not near complete but it's alot closer than it was before :)
Offline MaaseyRacer
    • Fuelist
« Reply #55 on: April 23, 2010, 02:52:49 PM »
Heat it up with a torch, and bend it where it needs to go.
1961 CB72
1961 CB77
1962 CB77
1962 CB77
1965 CB160
1970 Triumph Bonneville
1972 Honda CB450
1975 Norton Commando
  • Member #4842
« Reply #56 on: April 23, 2010, 09:24:18 PM »
And now, as promised, more pics  ;D
They're a little dusty right now so I'll get some better ones one I clean them up some.
  • Member #4842
« Reply #57 on: April 24, 2010, 08:59:13 PM »
Quick pic I shot of the bike in it's current state:
(and yes, the brake lever is hanging low. forgot my retainer spring  :P)
Offline HavocTurbo
  • Angry little bastard of an
  • Can you tell?
« Reply #58 on: April 27, 2010, 01:11:42 PM »
Looks kinda like a short wheelbase hill climber..... nice!
'48 HD Panhead - Exxon Valdez
'78 CB550K - Fokker CB.3
'78 Honda CB750K - Mavrik
09 XL883L - No Name
  • Member #4842
« Reply #59 on: April 27, 2010, 05:11:23 PM »
A new idea that I'm playin with....
Opinions?
Offline HavocTurbo
  • Can you tell?
« Reply #60 on: April 29, 2010, 10:25:53 AM »
Those Flanders bars?
Looks good.... but the grips kinda look out of place?? Not sure.
Hmmmm...
09 XL883L - No Name
  • Member #4842
« Reply #61 on: April 29, 2010, 10:34:10 AM »
The bars are actually 2 separate pieces. I had a set of stock bars off a parts bike that were bent so I cut them up to make those. It's more of an experiment in design right now more than anything, if I decide to go that route then I'll get some tubing and bend it to create a single bar. The grips I had laying around an had just thrown them on there to see what they'd look like.
Offline HavocTurbo
  • Can you tell?
« Reply #62 on: April 29, 2010, 10:38:53 AM »
Wow.... hadn't noticed that.  :D
My opinion?   Make slugs to weld in the ends of the bars. That way there can be no "crimping" of the bar ends at the clamps.
Very cool man.
09 XL883L - No Name
  • Member #4842
« Reply #63 on: May 06, 2010, 08:39:33 PM »
So I recently traded someone my 4-4 drag pipes for a set of 4-2 that came off of a '78F. I've played with every header/collector combo that there is with this set and this is what I've come up with finally:
Header pipes lined up
Another shot of the headers
This is where I'm scratching my head. The hangers are designed to go on the passenger peg brackets, yet the end of the pipes aren't lined up when there's a bolt through the hanger. Is this how 4-2s normally look when mounted to the bike? I'll get some side shots tomorrow.
  • Member #4842
« Reply #64 on: May 06, 2010, 09:45:57 PM »
On a completely different not, I pulled the exhaust and put my bike up on the lift to pull my forks (they need new seals). Since I already had them off I took one of the apart to measure the tube. I knew that they looked slightly longer than stock, but I didn't realize that they were.....
... wait for it ....
29 inches long!! So now I'm hoping that I have a set of standard forks in storage...... :-\
  • Member #4842
« Reply #65 on: May 24, 2010, 06:29:17 PM »
*Laughs Maniacally*
IT'S ALIVE!!!
Today is a day 3 years in the making  ;D For the first time since I've owned it my bike moved under it's own power. Rode it to the end of the block and back. Still needs lots of work, but I'm excited so I thought I'd share.
  • Member #4842
« Reply #66 on: May 26, 2010, 02:27:11 PM »
Well, looks like I got excited a little too early. Dropped my oil pan last night to check the screen on my oil pump. Once the pan came off I found 2 metal chunks and what appears to be a retaining ring for one of the bearings.  :'(  So last night I unbolted/disconnected everything I needed to so I can pull the motor once again. Gonna throw it on the bench, tear it down completely and see what's going on in there. I know that this forum is gonna be invaluable during this process, making a parts list as we speak. I'll get pictures up a little later this evening of the pieces I found.
  • Member #4842
« Reply #67 on: June 05, 2010, 06:10:31 PM »
I know I've been slow on the updates, but have been getting some work done. Finally got the cases split earlier today and guess what I found.....
Yup, those would be ball bearings  :(
...and the shattered bearing that they came out of  >:(
Other half of the case just looks like it needs a good cleaning.
Upper half of engine that I've been trying to get cleaned up. Thinking about getting all of the parts hot tanked, anyone done this with good results?
So now I'm looking to source bearings (going to replace all that need it of course). Need to start ordering parts on my next check.
traveler
« Reply #68 on: June 05, 2010, 07:08:08 PM »
Damn bad luck! >:(
These are the times when most would give up.......I would urge you to have patience and do what you can, when you can.
This bike is DYING for some cafe work....clubman's, a 'glass seat with bumstop, and some 4-2's or 4-1 exhaust.
Cafe this bike.....it will love you for it! ;) :D
~Joe
  • Member #4842
« Reply #69 on: June 05, 2010, 07:13:01 PM »
There's no way I'm giving up on this, if I do I won't have the motivation to rebuild the other 2 motors I have and put them in the pile of parts I have in storage :D.
As for the look, I like the looks of that cafes and am doing something similar but not quite.
  • Member #4842
« Reply #70 on: June 08, 2010, 06:53:44 AM »
So yesterday I dropped off parts at the machine shop. I took them to a very reputable shop in the area that has experience working with aluminum. $60 for the jugs, head and both halves of the case. So while I'm waiting for them to be finished I need to source bearings and start work on a couple things I wanna do to the rest of the bike. I plan on moving my electrics under the tank (except the battery of course) and I wanna fab up a plate holder/brake light. More pics to come soon  ;D
  • Member #4842
« Reply #71 on: August 09, 2010, 09:17:32 AM »
So I know it's been awhile since I updated, been caught up in other things. HOWEVER, there has been good news. Went in on Fri and got the title, tags and insurance for the bike. Have made lots of progress on the bike itself, will be posting pics this evening. I ended up swapping the broken motor for another one that I had lying around the garage. Now I just need to source new tires and tubes (hopefully for less than the $80 a piece that I've already been quoted).
Offline HedNut
  • Underwater Basket Weaving
« Reply #72 on: August 09, 2010, 09:44:13 AM »
Very cool build man! Sounds like an adventure to me!! Crazy how the bearing blew up like that on the inside!! Woohoo  Good luck! Can't wait to see you driving it!! Cheers!
  • Member #4842
« Reply #73 on: August 09, 2010, 12:24:38 PM »
WooHoo!!! Just ordered a new front and rear tire from AMT, $82 shipped for a set of Duros. The reviews on them were good enough that I felt they would work till I could save up for some better ones.
  • Member #4842
« Reply #74 on: August 10, 2010, 08:17:12 AM »
Well, tires were on backorder so I got a new tube for the front and am gonna roll what I have till this winter. And now, PICS!
