Author Topic: Head gasket Leak  (Read 5236 times)
Offline tlbranth
Re: Head gasket Leak
« Reply #25 on: June 23, 2009, 09:26:56 AM »
With a chunk of granite or thick (1/2" or better) plate glass and some stick-down abrasive paper and some patience, you can true up the head and block yourself.
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline WFO
  • Will work for powerbands
« Reply #26 on: June 23, 2009, 12:17:04 PM »
I re-used as suggested, torqued to 22lbs using Two Tired's torque pattern and Honda gaskets:
5lbs in sequence
10
15
20
22
let it sit overnight then loosen in opposite sequence:
20 (may already be loose)
15
10
5
Then tighten again:
5
10
15
20
22
No oil whatsoever.  Perfect.
82 cb650 sc nighthawk - 78 kz 650 b
Offline CBGhia
« Reply #27 on: June 24, 2009, 02:40:34 PM »
Well, tonight i am going to roll it out, clean it off and try the athletes foot spray to try to locate the exact source of the leaks.  If work wasn't taking up so much of my time, I could get things done on this bike   :P
