Author Topic: 550 Happy Ending! - with video!  (Read 4027 times)
Offline B.O.X.N.I.F.E.
  • The Stumped
« on: June 22, 2009, 06:00:02 PM »
3 months and more hundred dollar bills later than I care to think about and she's at a very pleasing 97%
Here's the before video after a tune up and tank clean (running on 3, sometimes 2 cylinders at idle) -
And here she is this afternoon -
So here's the list if you dare:
Complete top end rebuild -
Rings
Cam chain tensioner
All new gaskets, o-rings, misc.
Valve seals
Valves lapped
Stainless allen bolts
Oil pan gunk cleaned
Static timed, full tune up
Plugs
Exhaust gaskets
Exhaust painted
Cracked cases welded
Carb overhaul
OEM gasket kits
Rebuilt petcock
Feul line, inline filters
Sync
Foam air filter
+ Brake caliper rebuilt
Front fork seals & oil
Spitfire II tires
RK 530 Chain
Front & rear sprockets
Seat cover
Clutch cable
OEM chain adjuster bolts
Centerstand spring
Fuel cap rubber seal
It's a damn laundry list.
Did 120 miles yesterday on county roads & interstate highway, performed beautifully.
Compression #'s - 130,130,130,135  ;D ;D
Remaining problems
A new development after I let a guy sync it - a weird high pitched metallic rasping at higher RPM, especially at the top of 2nd gear before going into 3rd. Sounds oil starved to me, but it's just below the full mark. It's going to take some detective work and help from you guys later on. Shifter is also still pretty clunky, more so than I think would be expected (when new at least). A weird 'tin can' sound persists on heavy deacceleration.
« Last Edit: June 22, 2009, 07:53:33 PM by boxnife »
1974 CB550
Forever West
Offline Hush
Re: 550 Happy Ending! - with video!
« Reply #1 on: June 22, 2009, 06:19:05 PM »
Sounds good, you don't want them perfect otherwise we don't get to fiddle. :D
Offline robe0531
« Reply #2 on: June 22, 2009, 06:24:25 PM »
sounds and looks good
1978 cb750k
1968 Honda ca160
Offline Dave-and-his-550
  • I know the pieces fit...
« Reply #3 on: June 22, 2009, 07:05:22 PM »
Those exhaust joints/connectors. (The ones that hold in the exhaust to the cylinder head) Are they stock? I like them flat like that. The ones that came on mine are finned.
  • The Stumped
« Reply #4 on: June 22, 2009, 07:08:49 PM »
I assumed it was part of the aftermarket exhaust.
1974 CB550
Forever West
ateamsam
« Reply #5 on: June 22, 2009, 07:58:39 PM »
i have the exact same bike, except that yours looks nicer and sounds like it runs better!  Congrats!  Did you do the work yourself?
  • The Stumped
« Reply #6 on: June 23, 2009, 04:05:59 AM »
All of it but the carb sync. He leaned my needles out too since she was still running a little rich. Although I'm thinking of picking up a Morgan and syncing myself in the future. Rolled the bike in my house and rebuilt the motor in my bedroom. Ah, single life!  ;D
1974 CB550
Forever West
Offline 750goes
  • it will live
« Reply #7 on: June 23, 2009, 04:40:08 AM »
Good job Boxnife,
It is hard to diagnose from video, but your tappets still sound quite chattery, and also possibly the cam chain tension ??. Not being critical or picky, thats what it sounds like to me.
But it could well be just a carb sync to bring it all together..
the more you do it , the better it gets.. :)
Just rebuilt my carbs for the second time in two years, because I let it sit for a year with old fuel in them.. plugged mains and idles, plus I did the floats again, and found one carb was way out of spec..
reset all to standard and it started straight up and idles very nicely - they still need to be synched though..
Offline razor02097
  • Not a fool, just an
  • Yes its a Honda You got an F'in problem with that?
« Reply #8 on: June 23, 2009, 05:55:23 AM »
Good to hear you got her going,  projects are never "done" they just start a new volume  ;)
I just love happy endings
Project Rina
That is an inconceivably egregious transgression against my rudimentary concordance of socially shunned individuals.
  • The Stumped
« Reply #9 on: June 23, 2009, 09:01:40 AM »
Good job Boxnife,
The old tensioner was destroyed. No face on the slipper, broken tensioner adjuster. I'm guessing the cam chain is a little wiped out. It may sync up better after tuning, he said the mercury wouldn't flatten out all the way on all 4 carbs.
1974 CB550
Forever West
andy1976
« Reply #10 on: June 23, 2009, 11:09:52 AM »
That sounds mint! Just recently got my 750f running, but to be honest she's to quiet.
What exhaust do you have?
Offline bikerbart
« Reply #11 on: June 23, 2009, 11:55:43 AM »
Happy Ending!I heard about loving your bike,but not LITERALLY!!!ha ha
Offline Laminar
  • Retsam
« Reply #12 on: June 23, 2009, 12:02:58 PM »
This isn't the kind of happy ending video I'm used to.
  • The Stumped
« Reply #13 on: June 23, 2009, 02:34:40 PM »
It's a 4 into one - not sure who makes it though. Seems like a generic old aftermaket setup.
I just told my girlfriend "I'm either doing it with you or the bike" - I spent a lot of time with the bike.
1974 CB550
Forever West
Offline Accolay
« Reply #14 on: June 23, 2009, 05:49:47 PM »
Man, that is some great stuff! Your video just helped to motivate me through my own 550 project....hopefully done soon...
1977 CB550F
  • The Stumped
« Reply #15 on: June 23, 2009, 08:47:38 PM »
Keep on it man. I did it over three months and just didn't give up. My roommates thought I was crazy and that the bike was a piece of junk because I was literally working on it every day after work or up to my eyeballs in my shop manual. There IS a light at the end of the tunnel!!
1974 CB550
Forever West
Offline razor02097
« Reply #16 on: June 24, 2009, 04:58:22 AM »
As long as its not the headlight on a train :o :o :o :D :D :D :D :D
Project Rina
