Author Topic: 72 motor in a 78 frame  (Read 958 times)
Offline robe0531
« on: June 23, 2009, 01:29:43 PM »
hi i am rebuilding my 78cb750 motor and i want to keep riding i have a 72 cb750 motor with carbs will i be able to mount the 72 motor in the 78 frame so i can keep riding while i rebuild my 78 motor
1978 cb750k
1968 Honda ca160
Offline mkramer1121
Re: 72 motor in a 78 frame
« Reply #1 on: June 23, 2009, 01:36:17 PM »
short answer, yes, long answer, you need to switch the exhaust stubs from the '78 to replace the spigots on the '72 if its an original exhaust
Offline Patrick
« Reply #2 on: June 23, 2009, 01:37:21 PM »
I have a K2 750 engine in my 1978 F3 750 frame right now. It works fine. I used the F3 air box and the F3 carbs and the K2 exhaust.
Patrick
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Offline robe0531
« Reply #3 on: June 23, 2009, 01:41:57 PM »
awsome
thanks for the fast response
i love these forums
1978 cb750k
1968 Honda ca160
Offline Patrick
« Reply #4 on: June 23, 2009, 01:45:19 PM »
Oh yeah, one other thing to consider. The K2 oil tank will not bolt up to the F3 frame. Yet the vent spigot on the back of the K2 engine is smallerr than the spigot on the F3 motor and the connection on the F3 oil tank is larger than the spigot on the K2 oil tank. The F3 oil tank has only one vent instead of two like the K2. So you will need a reducer in the oil line from the tank to the engine. No big deal, but it is a difference.
Patrick
« Last Edit: June 23, 2009, 01:48:03 PM by Patrick »
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
