Author Topic: Worked with a Honda Factory trained mechanic on my 550K today  (Read 1458 times)
Kelvin8
« on: November 12, 2005, 08:02:08 PM »
got the valves adjusted properly, carbs adjusted (but not balanced yet), point gap and timing adjusted. However, looks like I have a bad coil on my 1/4 cylinders. Get a spark, but not a strong one. 2/3 are firing fine. He said he'd stop by monday with another coil. Looks like about all I need now are new tires and a new petcock. WooHoo!
Offline hymodyne
Re: Worked with a Honda Factory trained mechanic on my 550K today
« Reply #1 on: November 12, 2005, 08:21:37 PM »
check the ground and all connections on the coil you think is bad. also look at wires and plug caps (ohm meter) file down the stacked metal posts on each end to get to new bright metal before you reinstall. I hit all those newly sanded or filed connections with a shot of clear enamel afte reassembly.
hym
Kelvin8
« Reply #2 on: November 13, 2005, 07:03:45 PM »
Hym;
Thanks for the advice. Oxidation = insulation, doesn't it.
Kelvin
« Reply #3 on: November 14, 2005, 02:52:20 AM »
Oxidation=intermitent insulation hence intermittent electrons and faults
Offline Mark M
  • This is what the 10 year old me wanted for Xmas
« Reply #4 on: November 14, 2005, 03:38:57 AM »
Oxidisation = resistance = heat .....which is much worse, just ask anyone who had their electics melt or ....workshop burn down!
No not me, but it's not an uncommon story.
In the UK anything over 40 years old only needs insurance and Fuel.
Kelvin8
« Reply #5 on: November 17, 2005, 10:42:20 PM »
Turned out to be a carb problem. Low Speed jet on #1 was clogged and fuel wasn't flowing freely, plug fouled so neither #1 nor #4 was firing properly. Fixed it.
Offline Killer Canary
  • Typical Bran Muffin
« Reply #6 on: November 18, 2005, 07:15:26 PM »
A "Honda Factory Trained Mechanic" installed my plug wires on the wrong cyjinders and then tried to tell me the bike was running like #$%*e because it had a burnt valve!
It was running fine when I dropped it off the day before.
Now I do all of my own work.
Your guy sounds trust-worthy;not all of them are.
Kawi GPz900, H1
Kelvin8
« Reply #7 on: November 18, 2005, 07:41:05 PM »
This guy has a collection of almost all the SOHC 4s. He's the husband of a co-worker of my wife's. He's got most of the specs in his head. Anyway, he was showing me the proper procedures for tuning and adjusting everything. I told him about this web site.
Kelvin
Offline needswork
« Reply #8 on: November 18, 2005, 10:45:28 PM »
Way to go Kelvin8, be extra nice to his wife (although I'm sure you are anyway)  :)
'78 CB 550K fixer-upper. The bike needs work, I sure don't!
