Author Topic: Checking bearing clearance on CB 750..?..?  (Read 1269 times)
« on: June 25, 2009, 07:59:56 PM »
This is a bit like a poll, looking for answers/ thoughts,  from those who have used plastiguage and replaced at least one set of CB 750 bearings
Guy has a 30 yr old oneowner 750, say 30,000 miles, running fine.
It has a trans problem, and cases are coming out & getting split, to fix problem. Top end is staying on.
Not under a stiff time constraint, motor is apart a few days..
Upon inspection, berings & crank appear fine, look quite good.
Hers is the Q, would you;
 put it back together cuz it looks good..?
 or..
 plastiguage it and check, seeing as it is already apart?
Offline bucky katt
  • i am a pastafarian!
    • facebook
Re: Checking bearing clearance on CB 750..?..?
« Reply #1 on: June 25, 2009, 08:04:43 PM »
check it, no question about it.
Mark Twain - Notebook, 1894
Offline mystic_1
  • 1970 CB750K
« Reply #2 on: June 25, 2009, 08:27:45 PM »
Do it.  If you don't, you'll forever wonder.  Only takes a little while.  Check the rods too.
mystic_1
- John Augustus Shedd
« Reply #3 on: June 25, 2009, 08:32:11 PM »
If the engine was running fine and the bearings look good why screw around with it?  ::)
Offline HavocTurbo
  • Angry little bastard of an
  • Can you tell?
« Reply #4 on: June 25, 2009, 09:53:54 PM »
See that's what puts me on the fence.
I say go with your gut and see what happens. It's a tough choice for sure.
'48 HD Panhead - Exxon Valdez
'78 CB550K - Fokker CB.3
'78 Honda CB750K - Mavrik
09 XL883L - No Name
« Reply #5 on: June 26, 2009, 10:13:58 PM »
6 of 1 or a half dozen of the other.
I say it all depends on how much cash you're putting into it.
« Reply #6 on: June 26, 2009, 10:19:19 PM »
They are not  really putting any cash into it, merely opened it up to change one part.. Motor/ lower end had never  previously been opened up.
Offline CB750F2
  • Pat's first Honda 750 F2
« Reply #7 on: June 26, 2009, 10:58:32 PM »
I would check the big end rod clearances but not the mains. The big ends are subjected to more abuse than the mains. Just my opinion, Pat
Regards
Pat from Australia
« Reply #8 on: June 27, 2009, 05:31:58 AM »
If the shells are even grey and clean, bolt it back up with out silicone everywhere
« Reply #9 on: June 27, 2009, 09:52:57 AM »
Throw her back together then rather than open up a can of worms.
« Reply #10 on: June 27, 2009, 10:01:57 AM »
Can is already open, and you can see the worms, and you have looked at the worm, and they looked good.. but do you want to measure the worms?.. to see if they will last a few months.. or another decade..
NOTE** I was referring to checking the exposed mains, not taking off the rods caps, in this topic.
 Some folks check their compression, just because
 Why? probably because they want some indication of engine condition.. I am thinking..
« Last Edit: June 27, 2009, 01:31:28 PM by 754 »
Offline ofreen
« Reply #11 on: June 27, 2009, 12:31:34 PM »
Agreed.  The only reason I'd do it is out of scientific curiousity, if I thought I was going to measure again in another 30,000.
Greg
'75 CB750F
Offline mystic_1
  • 1970 CB750K
« Reply #12 on: June 27, 2009, 02:02:38 PM »
This is exactly why I'd do it.  Knowing is good, and this measurement is so quick and easy to take when the motor is at this stage.
mystic_1
