Author Topic: HELP!!!! Honda cb360  (Read 7240 times)
oppie2000
« on: June 27, 2009, 03:54:07 AM »
I have a 1975 Honda cb360, I've had it for about a year and a half and its always ran like a champ. i took it out for its first ride of the season 3 days ago and it was fine. went to ride it the very next day and i was getting almost nothing out of the right cylinder. getting good exhaust out of both pipes at idle, but when i go to take off hardly anything out of the right side. just some sputtering and backfires, eventually the right side seems to cut off completly. I would greatly appreciate any and all help as this is driving me crazy!!!
Offline jamesb
Re: HELP!!!! Honda cb360
« Reply #1 on: June 27, 2009, 04:35:05 AM »
try your points i had one of my bikes do the same thing. and it was the lobe on the contact points had broken off.
Offline Johnie
« Reply #2 on: June 27, 2009, 06:41:05 AM »
Could have a blob of dirt in the jet too.  Easy enough to pop off the bowl and clean the jets.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
oppie2000
« Reply #3 on: June 27, 2009, 02:30:55 PM »
Thanks for the input guys, i just adjusted the points. they didn't seem far out, though i know it doesn't take much. i used the paper method and got them both dialed right on. getting ready to take her out for a test ride. i'll post how it goes, also any other ideas out there in case this doesn't fix my problem?
Offline gane
  • Gane
« Reply #4 on: July 08, 2009, 08:28:25 PM »
Opie, The cb/cj 360s' were/are excellent rides, sudden loss of 1 cyl indicates either ign. or carb.if spark is present on dead cyl, would check for fuel delivery/clean jets. and vacumn diaphram at slide. luck g
Offline Green550F
  • Nothing is as cool as that which you made.
« Reply #5 on: July 09, 2009, 04:06:53 AM »
my 350 does this when I forget to turn on the gas! ::)
93 Kawasaki Voyager XII
70 Honda CL350 Cafe
Offline tbpmusic
« Reply #6 on: July 09, 2009, 07:17:54 AM »
If you adjusted both points to some specific value, then you're off-track. Setting the right side point to some specific gap means there is a good chance your timing is off.
There's a specific procedure for timing these beasties - read about it here -
http://www.hondatwins.net/forum/viewtopic.php?f=18&t=883
Bill Lane
Offline Green550F
« Reply #7 on: July 10, 2009, 08:13:40 PM »
yep! between the timing and the gap, the dwell is fixed. you have to set the gap first at the widest point and then set the timing. When setting the timing, check with a test light when the LF mark lines up with the stator mark. And be sure you are rotating in the correct direction! It makes a difference in accuracy of the timing!
70 Honda CL350 Cafe
Offline Simpson
  • I ain't no
  • Aged to perfection
« Reply #8 on: July 24, 2009, 09:15:39 PM »
+1 vacumn diaphram
1970 CB750 K0
1975 CL/CB 360 Mix
Offline Bill Vaughan
« Reply #9 on: July 24, 2009, 09:55:06 PM »
Don't rule out a bad spark plug boot.  The originals are resistor type and fail with age/use on an intermittent basis at the beginning.  They are still available from Honda.
1972 Z50A
1973 ST90
1975 CL360
1971 CB450
1975 CB550
1978 FLH
2003 FLSTS
2006 FLHRSI
Offline cb650
« Reply #10 on: July 25, 2009, 05:32:54 AM »
After riding mine for years and Paul helping find my timing problem I looked at the diaphrams and both had little tears in them.  Right side was bigger. Without any to replace them at the time I smeared on a little scotchkote liquid electrical tape.  Been holding so far. Runs better than it ever has.
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« Reply #11 on: July 25, 2009, 05:50:56 AM »
       Sounds like a good fix Terry, who'd have thought. 8)
Member # 1969
Offline cb650
« Reply #12 on: July 25, 2009, 01:02:50 PM »
And in the mean time Dad found me a set of rebuilt ones on ebay.
Offline crazypj
  • I'm brill, me
« Reply #13 on: July 25, 2009, 03:31:17 PM »
"First ride of the season" it was sitting, probably needed nothing more than a good cleaning, particularly gummed pilot jets
PJ
