Author Topic: why wouldnt my bike go above 55MPH?? help  (Read 2458 times)
Offline razor02097
  • Not a fool, just an
  • Yes its a Honda You got an F'in problem with that?
Re: why wouldnt my bike go above 55MPH?? help
« Reply #25 on: June 29, 2009, 06:55:55 PM »
there is a small circle stamped in the metal base plate where the advancer rotor is suppose to point at.  Also the advancer has a pin key so its hard to re-install wrong.
Project Rina
That is an inconceivably egregious transgression against my rudimentary concordance of socially shunned individuals.
Offline cormier1989
  • [URL=http://img41.imageshack.us/i/69316472.png/][I
« Reply #26 on: June 30, 2009, 09:45:46 AM »
i asked a huy i know who works on older bikes and he says it sounds like a carb problem. My question is, if it is a carb problem where do you think it is that would cause the cylinder to not put out?
Offline razor02097
« Reply #27 on: June 30, 2009, 10:04:03 AM »
sometimes if its shy or its dad might find out  :D
Project Rina
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #28 on: June 30, 2009, 10:40:45 AM »
Wires, plug end caps?
Offline MJL
  • Don't listen to me, I'm no
« Reply #29 on: June 30, 2009, 10:53:03 AM »
Do you have stock exhaust? If not, remove the air filter cover and go for a ride.
I bought new wire at my local bike shop, I just had to cut to fit.
Could be a bad coil. read this.  http://forums.sohc4.net/index.php?topic=54015.0
Could be a carb problem, there are several circuits in the carbs that come on and off at different speeds. (at more or less throttle)
« Reply #30 on: June 30, 2009, 11:59:42 AM »
Bad coil would mean 2 & 3 would be bad.
Offline SanDogDewey
« Reply #31 on: June 30, 2009, 12:04:51 PM »
After a while of riding a harley was passing by me and as soon as it passed my fonr axle my bike was back to normal and immediatly started picking up.
Maybe your bike has anxiety issues and felt better with another bike close by. ;)
Offline SanDogDewey
« Reply #32 on: June 30, 2009, 12:07:52 PM »
lol
