Author Topic: Honda CB750 Oil Tank Special Tool #736  (Read 2154 times)
Offline 736cc
« on: June 27, 2009, 01:31:49 PM »
Friggin paper towel tube does the dumping the oil tank trick like perfect.
But it took around a hundred messy oil changes to finally realize it ::)
[/URL][/img]
Offline mystic_1
  • 1970 CB750K
Re: Honda CB750 Oil Tank Special Tool #736
« Reply #1 on: June 27, 2009, 02:04:37 PM »
Niiiiice.
I have a plastic funnel that clips under the drain screw bung.  Works a treat with a length of plastic tubing on the neck of the funnel.
mystic_1
- John Augustus Shedd
Offline Patrick
« Reply #2 on: June 27, 2009, 02:18:15 PM »
I just crease a piece of cardboard to make a trough.
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
« Reply #3 on: June 27, 2009, 03:00:17 PM »
+1 on the creased..
 that tube, not sure how you get the plug out without hitting the tube.
 creased carboard always seemed to hold itself if bent right. I aso use a cardboard piece on a slight angle and place the oil filter with housing on it to drain out.. then inspect for metals and clutch crud in the oil..
Offline 736cc
« Reply #4 on: June 27, 2009, 04:12:09 PM »
I like the elegance of recycling garbage, and it squishes and forgives just right. Being the perfect length to pour into the pan clinches it. Everybody that owns a SOHC CB750 can now save their paper towel rolls for something important.
Fanagling the drain plug at the moment of release did get my fingers a teensy-bit dirty and oily uuuuuuuuueeeeoooo!!!!!!!!!!!! :D :D
« Reply #5 on: June 27, 2009, 04:49:47 PM »
Darn, and to think I used to waste all those paper towel tubes back in the 70s by poking a hole in them and using them as a shotgun tube  ;D
Great idea.
