Author Topic: Chasing the fuse blowing problem  (Read 1741 times)
Offline fmctm1sw
« on: June 27, 2009, 05:59:27 PM »
I posted about my fuse blowing adventures a week or so ago.  Did it again on the way to my kid's recital...  Didn't make it.  I hooked my ammeter up to it and didn't see anything approaching 15 amps.  Charging voltage was about 14.5VDC.  I then remembered that my high beam light was always on, I found that when I connected it I plugged it into the wrong connector in the headlight shell  ::)  I looked closely at my fuse holder.  While the center was clean (I wire brushed them a week ago), I notice the sides were crusty.  My battery terminals were the same way.  I cleaned them up good and we'll see if this makes a difference.  The next step is the buss fuse idea...
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline OldSchool_IsCool
  • Really feeling like an
Re: Chasing the fuse blowing problem
« Reply #1 on: June 27, 2009, 06:49:18 PM »
Order up a Higgins fuse box.  I installed one and haven't thought about fuses since!
http://forums.sohc4.net/index.php?topic=53063.0
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=250424136318
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline fmctm1sw
« Reply #2 on: June 28, 2009, 05:02:28 PM »
Thanks, I've seen that fuse thread.  I just felt with only one fuse on my 350, it was overkill.  I completed a 50 mile (or so) ride today with no blown fuse.  Perhaps that clean up job did the trick.  Time will tell.
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
« Reply #3 on: June 28, 2009, 08:54:05 PM »
My 750 would blow about 1 fuse for every 15 hours of riding time, pretty predictably. It was the fuse clips, heating those fuses up and slowly melting them.
I think ev0lution is marketing some neat fuseboxes with labels, but they are multi-fuse type. They are blades. It would be sort of like having built-in spares?
Offline Sporkfly
  • The frosty rider
  • Mmm, Guinness
« Reply #4 on: June 28, 2009, 08:56:39 PM »
Well, with only one fuse on the 350... I'd just switch it to a blade type fuse.
1977 CB550K
1979 CX500
1976 Suzuki GT500 Titan
