Author Topic: New engine build  (Read 10368 times)
Offline voxonda
New engine build
« on: June 28, 2009, 10:56:28 AM »
Finally start to build the 850 engine. Made arrangements to lighten the crank, new primary's with extra guide and more tension. Stronger camchain with M3 tensioner.
Can anyone tell me the gear ratio's used in the CR kit close-gearbox? Will not go that far but plans are to change 1st gear from 2.500:1 into 1.954:1
Thanks.
Rob
Offline voxonda
Re: New engine build
« Reply #1 on: June 28, 2009, 02:25:50 PM »
Took the studs out, four of them were more or less stuck but with some guided force they too came out. After the cleaning and VHT painting the HD studs go in. Hopefully can find some HD studs for the mains while I am at it.
Offline voxonda
« Reply #2 on: July 01, 2009, 12:00:46 PM »
No one about the gear ratio's? Ah well, let's move on there is a lot to be done.
Finished the camcover with the studs to keep things in place.
Have to blast it and spray some paint on it.
Offline DollarBill
« Reply #3 on: July 01, 2009, 12:11:09 PM »
For us that don't know can you explain the studs going all the way through the valve cover?  It looks cool anyway...
1975 CB750F Project Yellow Jacket - CBR600rr Swinger GSXR 600 Forks
1955 BMW R25/3, 1966 Honda CA160, 1975 CB400f, 1975 CB550, 1976 CB550
Offline voxonda
« Reply #4 on: July 01, 2009, 12:16:12 PM »
Yeah, they go through the cover and stop just above the camholders. The bolts help to keep the holders in place. Just for security reasons.
Rob.
Offline mec
« Reply #5 on: July 01, 2009, 01:36:27 PM »
hi,
can you make a picture of the M3 cc tensioner, please?
mec
Honda Monkey
Takeuchi TB 070
Massey Ferguson
« Reply #6 on: July 02, 2009, 10:52:50 PM »
Dynoman but he is temporarily out for maybe 1-2 months. If you find another source please let us know.
Offline voxonda
« Reply #7 on: July 03, 2009, 03:57:30 AM »
I am on to something, need to have the seizes of the studs. If anyone can give these, can make a leap forward.
Rob
Offline voxonda
« Reply #8 on: July 06, 2009, 12:17:47 AM »
hi,
mec
Hey mec,
I will as soon as I received it.
Rob
Offline mrosso
  • The before picture.
« Reply #9 on: July 06, 2009, 07:15:53 AM »
It's looking great. This will be a sweet, raceworthy ride when finished.
Does anyone have the measurements or a template for where the bolt holes should be on a reinforced valve cover?
Offline voxonda
« Reply #10 on: July 06, 2009, 07:36:38 AM »
Hey mrosso,
Hope everything goes to plan? What I did is the following, took a head with holders and placed it under a drill and centered it, then clamped it and mounted the cover. Take a centredrill and drill in the cover, do that four times for each holder. Remove the cover and head and drill the cover to the desired diametre. Hope it is a bid clear, if any questions you know where to find me.
Because I offer this thru voxonda.com, I have made a template for the mill.
Cheers, rob
Offline voxonda
« Reply #11 on: July 07, 2009, 10:25:43 AM »
Cleaned all the threads from the cases with the appropriate taps and so want to install the HD studs. Need some advice here, use Loctite or not? Or just dip in oil and give it 8ft lbs?
Thanks.
« Last Edit: July 07, 2009, 02:26:03 PM by voxonda »
Offline voxonda
« Reply #12 on: July 09, 2009, 01:33:12 PM »
Well made up my mind, no Loctite just a little bid of never-seez on the treads.
« Reply #13 on: July 09, 2009, 11:27:59 PM »
APE instructions for cylinder studs do not say to use lubricant or any compound on the threads.
1. "long threaded end must be installed in crankcase"
3. "After removal of stock studs, thoroughly clean holes with solvent and blow out".
4. "Using 2 wrenches, lock up two 8mm X 1.25 nuts on the noted (wasn't noted) location., bottoming out, then using a torque wrench torque to 8 ft, pounds maximum"
5. "Install head and following manufacturers torque pattern, torque head nuts to 20-22 ft pounds."
Offline voxonda
« Reply #14 on: July 10, 2009, 02:46:07 AM »
Thanks Jerry,
I have read that but, after working 30 odd years in construction of machines, I think a small mount of never-seez will not harm but only does good whenever removing.
cheers, Rob
Offline nippon
    • Classic Cycle City
« Reply #15 on: July 10, 2009, 06:52:33 AM »
Yes, you need a cylinder head and a mill for the first valve cover.
see at: http://www.classiccyclecity.com/gallery/thumbnails.php?album=44&page=1
nippon
Offline mrosso
« Reply #16 on: July 10, 2009, 05:37:52 PM »
Rob.
Rob, do the studs actually make contact with the cam towers or do they just hover above them a few milimeters?
Offline voxonda
« Reply #17 on: July 11, 2009, 12:36:29 AM »
They clear the towers about 1.5 to 2 millimetre, rest is done by the bolt. What I have done afterwards is mill the camholders 'clean' about .5 mm. So they are all the same height.
Rob
Offline mrosso
« Reply #18 on: July 12, 2009, 09:57:38 PM »
Rob
Thanks, Rob.
Does anybody screw the bolts all the way down until they make contact with the top of the cam towers? Is there risks/benefits to doing that? What about noise?
Offline voxonda
« Reply #19 on: July 12, 2009, 10:59:27 PM »
Think I made myself not clear, the studs do not make contact, but the bolts do! If they weren't they would do nothing to 'protect' the threads. Sorry if I was not clear.
Regards, Rob
« Reply #20 on: July 13, 2009, 02:51:26 PM »
Regards, Rob
yes I think something was lost in the translation mrosso. "Stud" in Rob's case is the "boss" in the camcover. the boss does not touch the cam tower. However the bolts inside the boss do, there are corresponding flat spots on the cam towers where the bolts will touch and actually press the cam tower into the head making a very sturdy cam platform.
I have a reinforced rocker box made by a machinist in Washington State, Les Barker. He said to run those bolts down into the cam towers to about 8 ft/lbs then lock in place with the lock nut. My bolts are smaller diameter than yours, Rob. Yours is overall more sturdy than mine, but I think anything is significant improvement over stock.
I am also up for suggestions on the torque used, 8ft/lbs sounds high.
« Last Edit: July 13, 2009, 03:00:55 PM by MCRider »
Offline voxonda
« Reply #21 on: July 13, 2009, 11:24:00 PM »
Thanks MC, you're as great help. My 'technical' english has some room for improvement. Think running the bolts into the camtowers makes not much sence since the bolts are compression loaded.
Regards,
Rob
Offline voxonda
« Reply #22 on: July 16, 2009, 01:55:26 AM »
Well, found my own solution for the main-studs. Wait and see.
Cheers, rob
Offline voxonda
« Reply #23 on: July 18, 2009, 10:58:57 AM »
While waiting for my M3 camchain guide, setting up the extra chainguide for the primary's against the uppercase. In doing so hoping to give the chains and tensioner a 'happier' life.
Anyone ever did something like that?
« Last Edit: July 18, 2009, 11:56:30 AM by voxonda »
« Reply #24 on: July 18, 2009, 11:05:44 AM »
Waiting for my M3 camchain guide so am setting up the extra chainguide for the primary's against the uppercase. In doing so hoping to give the chains and tensioner a 'happier' life.
Sounds cool! A stock tensioner mounted in the top case? Let us see!
