Author Topic: no lights - fuse and filiments "look" good  (Read 1059 times)
Offline 1974blaze
« on: June 28, 2009, 04:07:28 PM »
so, i have been messing with this 1978 cb125s for a few weeks.  mixed results, but had it running ok. just ok.  but i had been messing with it while waiting on a battery, lots of kicks.  then, i get a battery and the lights, all of them, don't work.  horn works fine.  fuse appears ok, headlight appears ok? when i first got it and i gave it a kick, i think there was a flicker of light from the neutral/oil lights.  now nothing.  what did i do? what should i do now?
thanks. help.
Offline HavocTurbo
  • Angry little bastard of an
  • Can you tell?
Re: no lights - fuse and filiments "look" good
« Reply #1 on: June 29, 2009, 03:34:56 PM »
I'm not certain but it seems to me that 1 of two things is going on.
Someone screwed with the wiring for the battery.
It's designed to run the lights off the engine not the battery.
I don't have a wiring diagram handy but it's probably the first one.
I'd start checking EVERYTHING with a circuit tester.
'48 HD Panhead - Exxon Valdez
'78 CB550K - Fokker CB.3
'78 Honda CB750K - Mavrik
09 XL883L - No Name
Offline 333
  • Time for change
« Reply #2 on: June 30, 2009, 06:11:09 AM »
The one I got was a 6 volt bike and the PO hooked it up to 12 volts.  Burned every bulb and fuse out.  The only way to truly check these is with a multi meter.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
