Author Topic: The forthcoming scrambler project (sohc but not 4)  (Read 3199 times)
Offline Green550F
  • Nothing is as cool as that which you made.
Re: The forthcoming scrambler project (sohc but not 4)
« Reply #25 on: July 01, 2009, 03:15:59 PM »
I freed my 350 by soaking the pistons with WD40 for 4 days(a new spray each day) and then bouncing carefully on the kickstarter while in 1st gear.(I'm only 160lbs) Do be gentle if you use this method! I'd hate to see more parts damaged by landing on the kicker too hard!
I'd recommend pulling the engine and going through it anyways. Once running, mine snapped a cam gear screw and bent all the valves. It cost me a new set of valves and a week of work for the shortcut. I would have bought the gaskets anyway...
93 Kawasaki Voyager XII
70 Honda CL350 Cafe
