Author Topic: correct fuel line route 1975 CB750  (Read 8390 times)
NOONDAYSUN
« on: June 29, 2009, 01:42:31 PM »
As the title says, does anyone have a good picture or diagram for the correct routing.
many Thanks
Offline mtr
Re: correct fuel line route 1975 CB750
« Reply #1 on: June 29, 2009, 01:52:38 PM »
Not to hijack your thread, but I'd be interested if anyone could do the same for a 77 550F. I noticed after reinstalling my carbs, the fuel line from the petcock was nudging up against intake boot, causing the line to slump a bit. I've tried to fix it as best I can, but I think I may have botched something when the carbs went back in.
77 550F / 80 750F
Offline Colonel
  • 750K5
« Reply #2 on: June 29, 2009, 02:00:47 PM »
NOONDAYSUN
« Reply #3 on: June 30, 2009, 06:28:43 AM »
« Reply #2 on: June 29, 2009, 05:00:47 pm » Quote
Please check the following threads:
http://forums.sohc4.net/index.php?topic=53382.msg571953#msg571953
.............Well hello Pandora! lol, thanks Col!
What i did in the end was;
    My 3/4 carb fuel pipe now lays over the top of the airbox intake boots, the fuel line from 1/2 carb up to the 'T'  which sits directly above the intake for carbs 1/2 is now approx 1 1/4 inches long. The fuel line goes though a hole in the mounting plate (1975 CB 750 F1) and up to the petcock.
  this has eliminated pretty much all of the up/down roundabout magical mystery tour which it was before, as the fuel line is now pretty much "level'  with good turns that dont go back on themselves.
Offline GammaFlat
« Reply #4 on: June 30, 2009, 06:39:29 AM »
This is fuel line routing on a K6:
The circle is where the line goes through the carb rack.  The square is the "T".
K6
K7
Suzuki GN400 - Ignition fixed!
03 KLR650 - Doesn't do anything very well but.. well.. does everything.
Offline lowmileage
  • Gotterdone
  • At Montauk Point Circa 1975
« Reply #5 on: June 30, 2009, 12:26:50 PM »
Glad to see I'm not the only one with this question ;D
1975 750 K5 Original owner -  11K miles.  On the road 8/09 after 26 years in storage.
2004 Harley Superglide - bought new
1973 Honda CL350 - sold in '75 to buy the "750"
