Author Topic: Serial numbers on the bike I just bought  (Read 1146 times)
Offline climbingaz
« on: June 29, 2009, 09:40:51 PM »
Not that I really care much because I only paid $100 for it, but the bike I just bought is supposedly a '78 CB 750K according to the frame ID tag.  But what has me a little confused is the ID or serial number on the engine shows CB 750E-1090125.  Is this engine a '78 or out of something much older?
Offline Gordon
  • 750K1, 550K2
Re: Serial numbers on the bike I just bought
« Reply #1 on: June 29, 2009, 09:49:50 PM »
According to that number the engine is from a K1.
Offline climbingaz
« Reply #2 on: June 29, 2009, 10:03:29 PM »
Yikes!  That's what I was afraid of.  Now I guess I've got a big decision to make.  Continue on with the restoration or part it out to recoup my cost.  Damn it!  Any suggestions?
Offline Gordon
  • 750K1, 550K2
« Reply #3 on: June 29, 2009, 10:06:02 PM »
Nuttin wrong with a K1 engine. ;)
Offline Spanner 1
« Reply #4 on: June 29, 2009, 10:16:55 PM »
Why dammit ? So you have a K1 motor, torquey and fast with simpler carbs than the '78...feels more ' classic' to ride, tho'....you may or not want that...
Offline jx25
« Reply #5 on: June 29, 2009, 10:27:51 PM »
i'm also failing to see the problem with the K1.... ???
I'd say you found a deal for $100
1978 CB750K (slightly modified)
1973 Suzuki GT250
1968 Ducati Monza 250(needs title)
1965 Bultaco 250(needs clutch work)
Offline Spanner 1
« Reply #6 on: June 29, 2009, 10:37:28 PM »
Found it for $100 gets irrelevant when you know how much you DID'NT need to spend on it starts to clock-up, if your smart and stay with this Forum ...!
Offline Dave-and-his-550
  • I know the pieces fit...
« Reply #7 on: June 29, 2009, 11:17:18 PM »
Well, the guy is going for a restoration project, having the original engine with the bike would probably be an important matter  :D
Offline Spanner 1
« Reply #8 on: June 29, 2009, 11:24:13 PM »
Agreed, but does he mean a 'restore it to good running condition', or restore it to spec. 78K..I thought the former ...
Offline climbingaz
« Reply #9 on: June 30, 2009, 07:26:06 AM »
Thanks for comments and "pep talk".  My goal for the bike was good-running, presentable looking cafe racer, not OEM-spec restoration, so I guess the older engine isn't THAT big of a deal.
However, I was really hoping to get this thing running and roadworthy for under a grand.  It needs a lot of work...had been rotting in the guys backyard for the past 15 years!  And now that I have no idea how many miles are on the engine, I don't know if a full rebuild is going to be necessary.  All I know is it turns over using the kickstart (it isn't seized up).  Also, the carbs are from '78 like the rest of the bike.
Please keep the comments coming!  What would you do?!?!
« Last Edit: June 30, 2009, 07:29:08 AM by climbingaz »
« Reply #10 on: June 30, 2009, 07:35:06 AM »
I would keep the spending as low as possible right now,concentrate on cleaning fuel system,change oil,give it a quickie timing,valve,cam chain adjustment,look for spark etc and get the engine running for an assesment as see where your at on that end. Hope she fires
« Reply #11 on: June 30, 2009, 08:31:44 AM »
Check chain alignment, to run early engine, you must change or hin the sprocket holder.
 I have a late F engine to trade for early, too basd you are not closer..
