Author Topic: stripped threads  (Read 1132 times)
Offline SOHC4ever
stripped threads
« on: June 30, 2009, 09:20:45 am »
Uhg.
The big, bad motorcycle mechanic in me has been undone by the common bicycle.
The nut and bolt that holds the handlebars on my bicycle are in a rough state. The nut turns and turns and turns, but just won't un-thread. I suspect that I'll need a new set, but getting those out of there is real perplexing. I think I might be at hacksaw stage, but if someone can give me some insight that might avoid it, I'd be much obliged.
Thank you kindly.
Offline Laminar
  • Retsam
Re: stripped threads
« Reply #1 on: June 30, 2009, 09:26:50 am »
If you can get a flathead screwdriver between the nut and whatever it's squeezing up against, putting some pressure on it that way might help it grab whatever threads are left on the bolt. If not, you can always try a nut splitter, a dremel, or a hacksaw.
Offline Green550F
  • Nothing is as cool as that which you made.
« Reply #2 on: June 30, 2009, 07:39:08 pm »
+1 for the dremmel! they can do wonders in tight places!
93 Kawasaki Voyager XII
70 Honda CL350 Cafe
Offline razor02097
  • Not a fool, just an
  • Yes its a Honda You got an F'in problem with that?
« Reply #3 on: July 01, 2009, 03:38:43 pm »
+10,000,000,000,000,000 for dremel
Project Rina
That is an inconceivably egregious transgression against my rudimentary concordance of socially shunned individuals.
Offline SOHC4ever
« Reply #4 on: July 02, 2009, 10:15:43 am »
BOOM!
1 flathead screwdriver and 1 "why didn't I think of that" moment and it's biz as usual. SOHC4.net to the rescue again.
Thanks to everyone.
Offline Laminar
  • Retsam
« Reply #5 on: July 02, 2009, 11:17:22 am »
Awesome.
