Author Topic: 81' honda cb750 main fuse issue  (Read 3758 times)
jonathansbrookshire
« on: June 30, 2009, 12:23:59 PM »
just bought a 1981 honda cb75 and im having a frustrating issue.  The bike runs great except for the fact that the main fuse blows when the bike gets hot and only seems to happen in gears outside of 1-3.  I can let the bike completely open up in neutral for as long as I like and it doesnt blow.  I dont have to hit a bump either.  Ive been on the freeway and replace the fuse 4x to get home (about 3 miles). Im using the 30a strip fuse which I believe to be correct and Im on smooth ground.  So I dont know if its a simple short or what... Help?
Offline OldSchool_IsCool
  • Really feeling like an
Re: 81' honda cb750 main fuse issue
« Reply #1 on: June 30, 2009, 01:55:13 PM »
Make sure your fuse clips are VERY clean and VERY tight.  Corroded or weak clips cause heating which can melt fuse innards.  A 30A fuse, eh?  Seems like a lot.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
jonathansbrookshire
« Reply #2 on: June 30, 2009, 02:12:15 PM »
yes, Ive got 4 15A glass fuses in my main box on the handlebars and my main fuse, in the left cover of the bike, next to the battery is a 30A strip fuse. Thats what Ive always had.  Though, I just noticed that the previous owner taped the box shut with black electrical tape and that there is a bit of corrosion on and around the connectors.  The bike ran fine up until about a week ago.  Im going to clean them now and test it out maybe later today when Ive got somebody around to give me a tow
Offline fmctm1sw
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
