Just to let you know the risks...
As the valves heat they expand, which effectively reduces the valve clearance to a smaller dimension than when the valves are cold. If you use the cold clearance dimension to set hot valves, the expansion will never reduce the dimension. Valve clatter and the risk of "hammering" the valve stem and the tappet adjuster. While I like mushrooms, I don't want these parts to look like them.
Set them in the morning after a good nights cool off, if you want a quiet valve train during run operations.
