Author Topic: '70 CB 750 K0 Instrument light cover  (Read 2371 times)
pecan26
« on: July 02, 2009, 12:58:08 PM »
I'm bringing a recently purchased 70 cb750 k0 back to life and the little colored light cover inside the tach--green for neutral, red for oil pressure have come off and are floating around inside the cover.
The tach has a plastic body not the metal one.
Anyways my question is how do I get the cover apart to get to the face of the tach so I can re-attach these things? I've tried everything i could beside short of wrecking the palstic.
There is a pciture of the tach here:
http://cgi.ebay.com/ebaymotors/Honda-CB750-K0-1970-CB-750-Sandcast-Tachometer_W0QQitemZ200357122147QQcmdZViewItemQQptZMotorcycles_Parts_Accessories?hash=item2ea6371063&_trksid=p4506.c0.m245&_trkparms=65%3A12|39%3A1|72%3A1171
Thanks for any help.
Offline markb
  • When I finish my current project I might be a
Re: '70 CB 750 K0 Instrument light cover
« Reply #1 on: July 02, 2009, 01:02:38 PM »
I need to do a set one of these days and I'm afraid you're going to have to cut the plastic.  Don't know where they are offhand but there are several threads related to doing just that.  You could try searching or maybe someone will chime in.
Mark
1969 CB750 sandcast #97 restored - Sold Restoration thread link
1969 CB750 sandcaxt #576 - Sold
1969 CB750 sandcast #1553 - Sold
1969 CB750 sandcast #1990 - Sold
1969 CB750 sandcast #5383 restored - Sold Restoration thread link
1970 CB750 K0 restored - Sold
2010 H-D Tri Glide Ultra Classic (Huh?)
Offline Johnie
« Reply #2 on: July 02, 2009, 01:27:47 PM »
I have taken both of mine apart on my KO.  Note on the very botton of the unit underneath is a plastic lip.  You have to carefully break that lip off.  Then the unit will slip out with the help of a small screwdriver.  Those colored lenses can be glued back in there.  Once you reassemble I have seen people use caulk or electrical tape to hold it in place.  I used the tape method as it is covered when you put the chrome bottom back on.  Plus, the tape I can easily remove to get inside again if needed.  While I had mine apart I went to a model store and got some orange paint to do the tip of the needed again.  Do not use any harsh cleaners on the OEM number faces as the color will come off.  I used a plastic polish on the inside and outside of the clear lense and it turned out real nice.
« Last Edit: July 02, 2009, 01:48:14 PM by Johnie »
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
pecan26
« Reply #3 on: July 02, 2009, 01:44:45 PM »
Thanks for the tips!
I wish I didn't have to wreck the plastic but you gotta do what you gotta do right!
Offline Johnie
« Reply #4 on: July 02, 2009, 01:49:12 PM »
Yah, I hear you.  That is the only way to do it.  You could use an Exacto Knife and cut that lip off too.  Comes off pretty easy.
Oshkosh, WI  USA
pecan26
« Reply #5 on: July 02, 2009, 03:17:38 PM »
Johnie,
Did you get new faceplates for your tach and speedo. Mine are in pretty rough shape the paint on the face looks like and old farm barn, the paint is all wrinkled. Do you haev any idea where these can be purchased. I've looked everywhere on-line andcan't find them.
technojock
« Reply #6 on: July 02, 2009, 04:17:00 PM »
Or you could just use a colored bulb...
Tony
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #7 on: July 02, 2009, 04:21:47 PM »
Johnie,
Check this post. I used a set from clocksndials, quite pleased with them, but as you see, there are other sources.
http://forums.sohc4.net/index.php?topic=36268.msg374348#msg374348
Offline Johnie
« Reply #8 on: July 02, 2009, 07:29:51 PM »
Johnie,
As you will see in Bob's post I got mine from www.yamiya.com from Japan.  Quality is tops, but you will pay around $180 for the 2 faces.  They are not stick-ons but the real deal.
Oshkosh, WI  USA
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #9 on: July 03, 2009, 04:26:04 AM »
Just thought I would mention this. When I rebuilt mine, on examining the original bulbs, I found them to 'carboned' quite a bit on the inside of the glass so they were not as bright as they once were. The original bulbs are spherical in shape.
I hunted all over for exact replacements, but never found any. However, I did find some  GE 1891 bulbs, they are 12V but rather than round, they are somewhat elongated, thus slightly taller. I replaced all mine with these and low and behold, they are noticeably brighter because they're new and it puts the top of the bulb slightly closer to the colored lens. I have no problem noticing them even in sunlight. It helps for those times when I forget to cancel a turn signal.  ;)
Offline CB750faces.com (Lecram)
  • CB750faces.com
    • Buy High Quality Honda gauge parts online!
« Reply #10 on: November 28, 2010, 11:51:18 AM »
Johnie,
Hi,
I am selling K0 face face plates with at least the same quality as the Yamiya faces for half the price.
See: www.cb750faces.com
or Ebay: http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=140481933741
