Author Topic: H rated tire on front & V rated rear  (Read 979 times)
Offline lowmileage
  • Gotterdone
  • At Montauk Point Circa 1975
« on: July 02, 2009, 12:59:57 PM »
If it's the same manufacturer and the same model tire, is this "mismatch" OK?  Aren't V rated stiffer which might cause an unbalanced situation?  Specifically I'm referring to Metzeler Lasertec's.
1975 750 K5 Original owner -  11K miles.  On the road 8/09 after 26 years in storage.
2004 Harley Superglide - bought new
1973 Honda CL350 - sold in '75 to buy the "750"
Offline HavocTurbo
  • Angry little bastard of an
  • Can you tell?
Re: H rated tire on front & V rated rear
« Reply #1 on: July 02, 2009, 02:21:53 PM »
Unless you spend most of your time at or above 100mph.....
I wouldn't worry about it until they start to show serious wear. The v-rated tire is slightly different and acts differently at the end of it's life.
'48 HD Panhead - Exxon Valdez
'78 CB550K - Fokker CB.3
'78 Honda CB750K - Mavrik
09 XL883L - No Name
Offline Alan F.
« Reply #2 on: July 02, 2009, 02:24:38 PM »
I would think it's fine as long as you stay within the H's rated speed range.  Tires are't 'harder' because they have a higher speed rating, it's just a slightly different design, but nothing you'll notice from the outside of the tire or by the seat of your pants.
Offline jeepster
« Reply #3 on: July 02, 2009, 05:19:00 PM »
I think I remember reading somewhere that this is actually dangerous...something about different rubber compounds or something...If you're concerned call up Metzeler or Avon and see what they say.
"An ounce of prevention is worth more if you break it up into nickel bags."
patrickd
« Reply #4 on: July 02, 2009, 06:13:10 PM »
I have a Metzler rear tire and a 40 dollar Chinese front. I can't tell whether they don't go together or not. Just don't try any roadracing and you'll be good to go.
Offline lowmileage
  • Gotterdone
« Reply #5 on: July 06, 2009, 06:10:17 AM »
Thanks all.  I'll think I'll keep it simple and stick to a pair of "H's."
