Author Topic: CB360, Not as Bad as I thought, stator question though  (Read 4869 times)
Offline Burke
« on: July 03, 2009, 04:54:44 PM »
When I bought my Cb750F the guy threw in a CB360 for an extra $25.00 he said the engined was seized and the stator was cracked.
Since my CB750 is having some frame work done, I decided to tear in the CB360, I taped the kick starter with a rubber mallet and it moved, so I thought the oil I shot in the cylinders did the trick. Then it stopped. The chain was so rusted that it was binding between the drive socket and the "guide". Once I removed the chain I dry tested and wet tested compression and wet they tested 150+. ;D
Then I removed the stator cover and looked for damage, I could not see any ???.
The rotor looks like something dragged acrossed it but looks ok. Is there a way to test the stator off the bike?
If the stator is good to go, a few gaskets, paint, and a rummage through my spare parts bin, I should have a running CB360.
Offline cb650
Re: CB360, Not as Bad as I thought, stator question though
« Reply #1 on: July 03, 2009, 05:13:02 PM »
Cool !!   What year?  The 74/5 had bad cam chain tensioners.  Most guys didnt like the 360 but I love mine now that its running good again.
Offline Tom in Newcastle......Ontario
  • Newcastle Ontario
« Reply #2 on: July 03, 2009, 06:42:38 PM »
I just lifted this off ........Do the ton site........might help for testing your stator
"On the plug that comes out of the stator there is 4 wires one of them is green and red don't worry about that one.  On the other 3 you take a voltmeter and you put it on the ohm setting and test them 1-2 1-3 and 2-3.  You should get 0 or close to 0 resistance on all 3 of them. If you get 1 or higher it is most likely bad.  This all info I read on the internet but it pertained to mine."
1978 cb 550k......stock,my first re-build
Loud pipes suck.......
If you buy something.........pay for it !
If you sell something .......ship it !
If you say you are going to do something......do it !
If you have a question about something......ask it !
When the seller answers ........let him know whether you still want it or not !
If you receive something .....let the seller know you got it !
If you get something and are happy/un happy with it .....let the giver/seller know !
If you have any kind of issue,shipping/receiving/quality/price/shipping charges etc !
Communicate
Offline Burke
« Reply #3 on: July 03, 2009, 06:44:32 PM »
It's a 74'.
Offline cb650
« Reply #4 on: July 03, 2009, 07:51:42 PM »
One of the "real" old timers knows of the recall for the tensioner.  I guess it the ser # on the engine has * stamps it was replaced.  Might have been replaced with out stamping.
Offline Green550F
  • Nothing is as cool as that which you made.
« Reply #5 on: July 05, 2009, 12:12:12 PM »
All 3 wires should "look" shorted together, but be isolated from the frame. the 4th wire is a neutral sense switch. it grounds out when in neutral.
93 Kawasaki Voyager XII
70 Honda CL350 Cafe
Offline Burke
« Reply #6 on: July 06, 2009, 03:16:14 PM »
I have a pink, yellow, white and on with a redstrip wires coming from my stator.  I will assume that the stripe wire is the ground.
And I am finding out that I am not that familiar with using a multi meter :-[.
When I put  my MM (it is a Blue Point) on the ohm setting there are two options, one with "H", or "AT"  My manual says nothing ???. Which one is the correct reading?
Offline Burke
« Reply #7 on: July 06, 2009, 03:39:17 PM »
Ok...I did a little research and found out out how to properly use my MM. ;D
I was getting an average reading of 1.2-1.7, but after I cleaned the plug ends with som contact cleaner, the reads averaged around .7 would this be satisfactory?
Offline Burke
Re: CB360, Not as Bad as I thought, stator question though (Or is it?)
« Reply #8 on: July 06, 2009, 05:38:43 PM »
I have now truley inspected the stator and rotor, the rotor has a crack near the bottom and it looks like the starter clutch has some damage. The clutch is loose and I can see the screws, they are loose.
If I pull and tighten everything up, will it be functional?
Or would I be better off finding one on e-bay?
Offline cb650
« Reply #9 on: July 07, 2009, 04:32:00 AM »
I'm no help.  I've only been kick starting mine for the past 5 years and it charges good so never had to play with it.
Offline crazypj
  • I'm brill, me
« Reply #10 on: July 07, 2009, 04:34:08 PM »
The crack on rotor is on the back/edge?
If so its a common fault, and its only the starter clutch outer steel case
 You could remove it completely or replace it, three #3 Phillips flat heads hold it on, pull rotor using rear axle (if you don't have Honda puller)
I sent one to Australia last year, leethal is on this site, he's on Honda twins as well.
 0.7 Ohms is OK for stator as long as it doesn't show continuity to ground (probably OFL on Blue point meter, any numbers mean it's shorted)
PJ
Offline Burke
« Reply #11 on: July 07, 2009, 04:50:32 PM »
PJ
Cool thanks.
I will try to fix it.
I did not show anything on the ground.
To remove it, do i just theard in the rear axel and pull it off?
Offline crazypj
  • I'm brill, me
« Reply #12 on: July 07, 2009, 04:54:57 PM »
Yep, unscrew 14mm head bolt and screw in axle.
 Should pop right off.
 Screws on back may be loose, usually they are damaged on threads but come out pretty easy
 If you need starter clutch I have another one, they come up on E bay pretty regular as well
PJ
Offline Bill Vaughan
« Reply #13 on: July 07, 2009, 08:40:27 PM »
If you decide that you're going to go further with the engine and want to know the details surrounding the tensioner (and other) updates, let me know.  I have copies of the factory service supplements and parts lists.
By the way, I have a 360 in the stable and found it to be a fun little bike.  Best of luck with yours.
1972 Z50A
1973 ST90
1975 CL360
1971 CB450
1975 CB550
1978 FLH
2003 FLSTS
2006 FLHRSI
Offline Green550F
« Reply #14 on: July 08, 2009, 07:17:17 PM »
Sounds like the Stator wiring is fine... The red striped wire isn't grounded unless you are in NUETRAL! it is connected to a switch outside of the alternator housing.
The rotor is a magnet. as long as the crack doesn't cause a structural issue it wouldn't hurt too much. The real risk is if it could seperate at 9,000 RPM.
70 Honda CL350 Cafe
Offline Burke
« Reply #15 on: July 09, 2009, 06:25:10 PM »
I took the rotor off using the rear axel (thanks crazypj) and found that the screws were stripped and the damage was pretty bad. Broke screws, stripped and the cracked piece is loose.
I am going to look for one and replace.
Thank for all your help guys.
This is why i love this forum! ;D
Offline crazypj
  • I'm brill, me
« Reply #16 on: July 12, 2009, 01:39:09 AM »
So you only need a good starter clutch or are the screw holes in rotor damaged?
Should be hundreds out there, pretty sure CB350 is same as 360
PJ
Offline Burke
« Reply #17 on: July 12, 2009, 04:37:17 PM »
Yeah, the screws were stripped in the rotor. I found one cheap on e-bay.
I should be good to go later this week.
Once my frame and engine is done-up, I will start a "Project thread".
Thanks for all your help guys. ;)
