Author Topic: 3 yellow wires that go to the alternator.  (Read 1120 times)
Offline cadaver
« on: July 04, 2009, 02:00:37 PM »
so i screwed up and 2 of the 3 wires that i marked the run to the alternator fell of so i don't know in witch order to splice them back together as ...one person says that it wont matter ..but i just wanted to get a few more peoples opinion first. thanks
Offline Hush
Re: 3 yellow wires that go to the alternator.
« Reply #1 on: July 04, 2009, 02:15:06 PM »
The 3 yellow wires run down to the stator and become seperate coils for charging etc so no I can't see it mattering as long as you hook them up correctly up by the regulator ie the 3 yellows in line (can't remember if it was the bottom row or the top row but you at least will know that I hope).
Hondamagic
« Reply #2 on: July 04, 2009, 02:36:10 PM »
It doesn't matter, as long as each yellow wire from the stator is connected to a separate yellow wire on the regulator.
Offline cadaver
« Reply #3 on: July 04, 2009, 02:52:59 PM »
thanks guys ....now I can hook all that up felling that things will go good ..now im back to finding out why im blowing my main fuse again ...last year i took my harness off and cleaned all the connectors and thew it back on and didnt have the problem till now ...URRRR...
Offline Alan F.
« Reply #4 on: July 04, 2009, 03:50:29 PM »
In that case you may have connector issues due to their age.
http://www.oregonmotorcycleparts.com/connectors.html has replacement connectors to renew our harnesses.
Offline Hush
« Reply #5 on: July 04, 2009, 04:20:59 PM »
If you removed the harness and treated all the connectors with Electric-grease you should not have to reclean the connectors again?...you did treat all the connectors with Dilectric grease didn't you!
Offline cadaver
« Reply #6 on: July 04, 2009, 05:16:22 PM »
yes i did treat it with the grease, it was just the main fuse part ...its kinda warn out ...so i just sniped the main wires and made a hookup for a blade fuse ...tadaaaaa problem fixed now ...ill half to come up witha blade fuse box that will hook up just like the old style .. thanks for your help guys . and happy 4th ..
