Author Topic: replacing upper bridge...  (Read 835 times)
Offline XxDarkEuphoriaxX
  • bangle bangle bangle
« on: July 07, 2009, 11:12:43 AM »
Hi, how difficult is it to replace the upper bridge in a honda 350F? Do I have to worry about anything sliding up or down, etc... anything coming out of alignment?
EDIT: also, what is the best way to strip the paint from the bridge, and re paint it? thx much
 adam :)
« Last Edit: July 07, 2009, 02:36:19 PM by XxDarkEuphoriaxX »
1972 CB350F
Re: replacing upper bridge...
« Reply #1 on: July 07, 2009, 02:37:17 PM »
bumpetybump ;)
1972 CB350F
Offline 736cc
« Reply #2 on: July 07, 2009, 03:10:16 PM »
Loosen 2 bolts on ends holding forks, remove handlebars, both gauges and any cables cables running thru the upper tree. Remove crown nut and spanner ut below it (shock tool or just punch it out (unscrew) w/ a drift or screwdriver. Lift off tree and watch ball bearings fall on garage floor....Lower tree will fall out if forks are not attached and watch THOSE ball bearings fall on garage floor....
« Reply #3 on: July 07, 2009, 03:33:48 PM »
hrm.. I don't have ny experience doing nything of the sort...
do you think it is something the shop should do or is it pretty easy?? thx
1972 CB350F
Offline turboguzzi
« Reply #4 on: July 07, 2009, 04:02:39 PM »
hei 736
unless the 350's fork is vastly different form other sohc's, no balls will fall on the floor when you lift the tree because the stem will be held in place by the flat adjuster nut.
TG
Online Alan F.
« Reply #5 on: July 07, 2009, 04:35:29 PM »
+1
« Reply #6 on: July 07, 2009, 05:01:27 PM »
so is it a pretty easy process overall?
1972 CB350F
Offline Patrick
« Reply #7 on: July 07, 2009, 05:07:22 PM »
Pretty basic.
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Offline crazypj
  • I'm brill, me
« Reply #8 on: July 07, 2009, 05:09:27 PM »
Very easy to take apart and re-assemble but you WILL NEED a torque wrench to put it back together or there is a good possibility of breaking it when you tighten pinch bolts around fork tubes.
 Not as weak as some Honda top yokes but not as easy to get hold of if you break it
PJ
« Reply #9 on: July 07, 2009, 05:11:37 PM »
already broke one, the second one is on its way, i tightened the 2 bolts too tight on the left and right sides, whatever they are called... but nyhow.
1972 CB350F
