SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
timing issues &*%*!!!
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: timing issues &*%*!!! (Read 828 times)
the technological J
Master
deliciouso!
on:
July 07, 2009, 01:31:47 PM »
so im now trying to fix my timing i adjusted the points clearances the 2-3 clearance was ok but the 1-4 was small (like less than .0015 the smallest feeler gauge) but after some very careful adjusting i got the clearances just right( around .014).. and now the bike wont idle just stalls and barely runs i have rotated the timing plate ( or base) slowly in both directions and nothing is helping
Logged
70 KO...sold to fund the ST
http://forums.sohc4.net/index.php?topic=88800.0(Alpha
74 Kaw 250 Enduro
http://forums.sohc4.net/index.php?topic=124278.0
K4 added to collection!
http://forums.sohc4.net/index.php?topic=104784.0
78 750K...
http://forums.sohc4.net/index.php?topic=60257.0
(Omega)sold to fund the K4
94 ST1100..Gone
72 750 K2 Stay tuned!
1timduke
Hot Shot
'75 CB550
Re: timing issues &*%*!!!
Reply #1 on:
July 07, 2009, 02:53:37 PM »
Are the points new? If you've changed the point position, reset the timing using the bulb or paper method. This should get you back running if it's a timing issue, provided other things haven't gone out, condensers and what nots.
-Tim
Logged
The only thing I miss about the South is Waffle House!
Spanner 1
Old Timer
CB 750 K0 ( always thought it was a K1!) + CB750K8
Reply #2 on:
July 07, 2009, 03:02:28 PM »
I think you need to start over with setting the point gap...
First turn the crankshaft until the 1+4 "T" mark is visible thru' the viewing hole, then continue to turn clockwise 90 degrees past the mark. This is where the lobe on the cam opens the points to their widest. The gap needs to be 14 thou. (.014 ) at this setting.
Repeat for 2+3 point.
Timing ( static ) is set by turning crankshaft to 1+4 'F' mark and then turning the points plate( the whole round plate ) until the 1+4 point is just opening...an ohm meter is best way to see it exactly. Tighten plate screws. Turn crankshaft to 2+3 'F' mark and adjust 2+3 sub-plate to make points just open at the 'F' mark. Done.....gap + timing...
Logged
the technological J
Master
deliciouso!
Reply #3 on:
July 07, 2009, 04:20:14 PM »
thanks it ended up there was a magic spot on the base and i had the idle set at 3000 some how it was way off... but i fixed this and syched it its like a new bike...
Logged
74 Kaw 250 Enduro
78 750K...
94 ST1100..Gone
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
