Author Topic: Top-end Gaskets  (Read 1050 times)
Offline mrosso
  • The before picture.
Top-end Gaskets
« on: July 07, 2009, 03:47:32 PM »
Can you put a Cometic copper base gasket on dry, or do you need to coat it with Gaskacinch? I read that you should only apply sealant on the head gasket, not the base, but Cometic's instructions say differrent. Experts, what do you think?
Offline mrosso
Re: Top-end Gaskets
« Reply #1 on: July 07, 2009, 06:09:10 PM »
No opinions on this?
Offline OldSchool_IsCool
  • Really feeling like an
Re: Top-end Gaskets
« Reply #2 on: July 07, 2009, 06:23:15 PM »
I put all my gaskets on dry, but I used OEM.  I did put a light bead of Aviation Sealer on the pucks.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline scondon
  • Mmmm......tasty bugs
Re: Top-end Gaskets
« Reply #3 on: July 07, 2009, 06:48:49 PM »
I'm no expert, but I used gaskacinch on my copper cometic base gasket just to be sure. Not sure it's necessary. Gaskacinch is pretty easy stuff, not so messy or prone to gumming things up like the silicone and other "sealant" type products.
Offline gane
  • Gane
Re: Top-end Gaskets
« Reply #4 on: July 07, 2009, 07:24:25 PM »
Mroso, Could be wrong, but the best reason for a copper base gasket which comes to mind is for turbo application where dropping compression ratio is desired. in this instance there are usually different thicknesses avail.and sometimes used in comination.in these situations, spray Copper coat is usually used. for stock motors, my preference is OE.dry. Fibre/carbon head gaskests have weeped since inception. issuring head and cyl surafaces are flat & true are a must of course, but in my experiance original failure is at oil passage orings allowing eventual deterioration  at gasket. coat ing these areas w/ Indian Head  shellac and allowing to dry before installation helps. luck G
Offline mrosso
Re: Top-end Gaskets
« Reply #5 on: July 07, 2009, 07:52:30 PM »
Good points... hmmmm... I have a Vesrah fiber base gasket and the Cometic copper. Anyone else prefer one over the other.
Offline Johnny5
    • CB350F build thread
Re: Top-end Gaskets
« Reply #6 on: July 07, 2009, 08:09:35 PM »
I got the gasket kit from Cycle X. I think it was Emgo.
Nothing on the base gasket. A light copper coating on the headgasket. Permatex Ultra Silver underneath the pucks (cleaned the sealant from the top of the pucks). Over a 1000 miles later, zero leaks.
www.kerosenecycles.com
1971 CB350
1973 CB350F
2006 Harley Springer Classic
Offline Gordon
  • 750K1, 550K2
Re: Top-end Gaskets
« Reply #7 on: July 07, 2009, 08:48:20 PM »
On the contrary, there are lots and lots of opinions on this subject.  Do a search for "gasket sealer", or something to that effect.
