Has anyone had the problem when you are trying to time a bike, you pull the trigger on the timing light and it draws amps from the bike and kills the engine?
I have the negative cord hooked up to the negative terminal on the battery
The postitive cord hooked up to the points, either 1-4 or 2-3, and the
detector cord hooked up to the cooresponding ignition plug wire. If i'm timing 1-4, then hooked up to cyl 1 plug, and timing 2-3 hooked up to cly 3 plug.
Get the bike idling nice around 1200 for a 75 CB400F, but then pull the trigger and it kills the bike.
Any thoughts? Thanks!
