Author Topic: complete ignition overhaul check list  (Read 909 times)
Offline 750four
  • Bomb's away!!!
« on: July 08, 2009, 03:06:50 PM »
I am in the process of overhauling a cb750 with the k1 engine. It's quite a basket case and instead of trouble shooting  the system I' m going to update and replace everything needed. So far I've decided on the dyna-s 1-2 ignition, the dyna green 3 ohm coils, dyna' plug wires and the oem plugs. I've already bought a new starter relay and I'm looking at a rectifier/regulator combo from Rick's.
My question is this:
Will this cover the entire ignition system?
and are there any suggestions on different parts?
The 750 will be a daily driver. I really look to make this a dependable ride. I've searched high and low and the Dyna-s system looks to be all I can really find. I've also heard people having low idle problems with the 3 ohm coils. Would 5 ohm be better for my application?
Offline cb750fbomb
  • is by no means a
  • "No hope? See, that's what gives me guts!"
Re: complete ignition overhaul check list
« Reply #1 on: July 08, 2009, 06:46:57 PM »
Check this out before you buy anything:
http://forums.sohc4.net/index.php?topic=54253.0
'77 CB750F2
“The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong it usually turns out to be impossible to get at or repair.”
Offline 750four
  • Bomb's away!!!
« Reply #2 on: July 09, 2009, 07:22:02 AM »
good link, I'll email them for sure. Anyone used this?
Does it replace the points?
« Last Edit: July 09, 2009, 07:32:07 AM by 750four »
Offline Laminar
  • Retsam
« Reply #3 on: July 09, 2009, 07:36:23 AM »
Tons of people have used it with great success. It doesn't replace the points, but rather it uses the points as a kind of relay for the actual ignition power, greatly increasing the life of the points and the reliability of the ignition system, for much less money that a Dyna.
Offline fishhead
  • Why don't you go.....Well, you know the rest.....
« Reply #4 on: July 09, 2009, 08:23:23 AM »
Heres a link where you can make a HEI triggered ignition system.
http://geocities.com/loudgpz/GPZheiModForPoints.html
Quote from:  Vanna White
Photobucket slide show (Fishhead Big Brakes)
http://s111.photobucket.com/albums/n130/dgfischer/Fishhead%20Big%20BRakes/?albumview=slideshow
