Battery purchased and installed...with varying success. First and foremost...
![](http://i166.photobucket.com/albums/u105/Weidbrewer/Bikes/IMG00102-20090801-1513.jpg)
+1 to Brandon and scunny. Fit right in. Good call, guys.
After that, I plugged in the battery and started testing stuff. Starter works, but the horn does not. Have to look in to he latter. Looking up front:
![](http://i166.photobucket.com/albums/u105/Weidbrewer/Bikes/IMG00103-20090801-1545.jpg)
That's good. Tail light is also lit, but the rear indicators aren't. Later, I sat down in a chair and I saw this under the rear fender. This it might have something to do with it?
![Wink ;)](http://forums.sohc4.net/Smileys/default/wink.gif)
![](http://i166.photobucket.com/albums/u105/Weidbrewer/Bikes/IMG00105-20090801-1625.jpg)
The signals do not blink right now. Flipping the switch, they just turn off. Tried the wires boh ways on the relay and nothing, so maybe it's blown.
A few other things that I'm not sure about. On this model, are there any lights that don't light up unless the engine is on? Normally, all the idiot lights come on when the key is turned on most bikes. In this case, the highbeam indicator, neutral and oil-pressure lights don't come on right now.
The neutral light is most likely because it wasn't in neutral. I don't have the clutch hooked up right now, and it didn't seem to want to shift in to it without it. The turn signal indicators also don't work, but if the signals themselves don't work... But, the other lights, I would have expected to come on.
Next on the list is the brake light. The main light is lit, but it doesn't brighten when the brakes are applied. (They aren't installed right now, but I thought the indicator was separate.)
Last, but certainly not least is the last little problem I noticed when I walked around the back of the bike...
![](http://i166.photobucket.com/albums/u105/Weidbrewer/Bikes/IMG00104-20090801-1548.jpg)
Notice that the key is in my hand that the tail is still lit. Well, that's certainly not right...
That's it for today. More to follow next time I get to work.
