Author Topic: Any tips on getting spark plug #2 out? (750 K7)  (Read 1249 times)
MrHellpop
« on: July 08, 2009, 09:38:50 PM »
I know getting spark plug #2 out is legendarily difficult, but the trouble I am having seems too crazy! I can get my ratchet with an 18mm socket into there, but it seems as though the socket is too big for the plug in there! All 3 other plugs were the standard NGK plugs and came out easily enough with the 18mm. Is it possible that the PO had some other type of plug in there with a different hex size? I tried both of the spark plug ratchet attachments I had (in addition to the 18mm): the 13/16 and the 5/8th!
What's going on???
Re: Any tips on getting spark plug #2 out? (750 K7)
« Reply #1 on: July 08, 2009, 09:55:43 PM »
Use the Honda tool kit box spanner, Most, if not all, sockets are too big round the outside
Offline BeSeeingYou
« Reply #2 on: July 08, 2009, 10:19:31 PM »
I have had no problem using a Craftsman 18mm spark plug socket.  Maybe it is a bit smaller around than their regular 18mm socket.
Offline KB02
« Reply #3 on: July 09, 2009, 04:22:22 AM »
get a set of metric deep well sockets. Start at 18mm and work your way down until you find the one that fits.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline Johnny5
    • CB350F build thread
« Reply #4 on: July 09, 2009, 04:55:34 AM »
I got the "spark plug socket" at my local Tractor Supply Company store. I think it has a little smaller outside diameter than a regular socket. It fits snug but Im able to get the plug out.
www.kerosenecycles.com
1971 CB350
1973 CB350F
2006 Harley Springer Classic
Offline scartail
« Reply #5 on: July 09, 2009, 05:21:30 AM »
I'd second this.
'89 Hawk GT, newly acquired, daily beater...
'76 CB550, was my daily beater... my cafe project...
'72 Yamaha R5, newly acquired project... donated to my buddy...
'67 Suzuki T20, still working on her too... Currently in pieces...
Offline Johnie
« Reply #6 on: July 09, 2009, 06:02:05 AM »
I also use the Craftsman 18mm, but I really have good luck with the socket in the Honda tool bag.  Should not be a problem unless the PO tightened it to tight or put something else in there?  Any chance the PO rounded off the plug so your 18mm can not bite it?
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline BeSeeingYou
« Reply #7 on: July 09, 2009, 09:34:54 AM »
My Cb750F sat for 25 years and I was able to use the Honda socket to get 3 plugs out but just barely.  It was hard to get enough leverage.  For the last one I had to use the Craftsman socket wrench as well as a 2 foot long pipe and it was difficult even with this.  Luckily everything came out ok in the end but I was a little concerned at first.  The only issue I have had with the Craftman socket is the rubber insert sometimes grabs the plug so well that it pulls off the wrench and stays with the plug and on those two center ones there is not enough room to grab it and pull it off.  So you have to back the plug out to get them apart.  Now that they have been loosened I can use the Honda tool without problems.
What is the real issue?  Is the plug rounded off?  Is it a different size?  Or is it just in there really tight?
« Last Edit: July 09, 2009, 09:39:34 AM by srust58 »
Offline Blasbo
« Reply #8 on: July 09, 2009, 12:09:31 PM »
I had the same problem with my K7. I don't remember specifics but it had a different size and brand in the number 2. I think I might have had to use an SAE socket to finally get it loose.
