Author Topic: Sealed battery mounted on it's side is leaking...help!  (Read 1705 times)
Offline Zev Fisher
« on: July 09, 2009, 07:00:24 PM »
Hi all-
I moved my battery behind my seat and mounted it on its side...and now it appears to be leaking. The battery is a Yuasa YTX12-BS and it was suppsed to be a "sealed" design.
Has anyone had experience mounting a battery horizontally? Ever had this issue? Is it possible to replace with a totally dry cell?
Any thoughts or suggestions would be greatly welcomed.
Thanks!
-Zev
Offline Bodi
Re: Sealed battery mounted on it's side is leaking...help!
« Reply #1 on: July 09, 2009, 07:14:20 PM »
This battery is "maintenace free", not a gel cel or AGM type: it's a modified wet cell battery and comes with a container of liquid battery acid you pour in to activate it (just like a standard dry charged lead acid battery). You can't put it on its side.
A gel cel can be put in any orientation I think, but I've noticed that every device I've ever seen that uses them orients them the same way, with the "top" up. Maybe they aren't super happy sideways or upside down?
The newer AGM batteries should be able to mount in any orientation as well from what I understand but again I've never seen an original equipment application where the battery is not mounted with the "top" up. This mounting may just be a habit left over from wet cell designing of course!
