Author Topic: order of operations?  (Read 788 times)
Offline grumpy
  • ..... '73 750K3 .....
« on: July 10, 2009, 03:20:43 PM »
I know I've seen this posted somewhere before but I can't find it....
When doing a tune-up, what's the proper order?
I think it's:
Valves
Cam chain
Points
Timing
Carb sync
Izzat right?
I know the first 4 are sort of interdependent. And I know sync is last...
Offline Alan F.
Re: order of operations?
« Reply #1 on: July 10, 2009, 06:49:18 PM »
My logic in this regard flows from the source of all rotation, the crank.
So what's driven first?
The points, set your gaps.
Timing
Then set your camchain tension
Then set your valves
Then synch your carbs
Just my thinking on it, the manual may have a better idea.
-A
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
« Reply #2 on: July 10, 2009, 06:53:57 PM »
i would say
points
cam chain
valves
check the cam chain again
timing
carb sync
ride and...
check timing again
whatever you do, don't get 4 friends and do it all at once, and the bike will implode.
