Author Topic: Countershaft and bearing plate CB750 Help!!  (Read 985 times)
Offline michrobi
  • Goldenrod blew a 5" hole out the front with a
  • On a neverending quest for more garage space
« on: July 11, 2009, 03:30:18 PM »
I just got my cases back together and am putting the shift linkage/etc. back together. My problem is the countershaft is poking out of the case about 1/8" too far, and I can't get the countershaft bearing plate on. I have ran all through the gears and rolled the engine all around trying to get the shaft to pop in, but it isn't happening. Here are some pics...
The bearing plate as far as it will go
the shaft from a flush angle
The inner bearing
Anything other than splitting the cases I can try to get the shaft to seat into the case bearing a little more?
-Mike
'78 CB750F All stock except for the powerplant. Jived it off my Dad in the spring of '94. He had it since 1980 and it's the first bike I ever rode on.
Current project: http://forums.sohc4.net/index.php?topic=67756
How's them SOHC4 patches coming?
Offline Sweep
  • Just remember there are no stupid questions, just some idiot asking them.
Re: Countershaft and bearing plate CB750 Help!!
« Reply #1 on: July 11, 2009, 03:47:11 PM »
I am away and have no access to my books/pictures but isn't that shaft sprung on the right side of the primary?  I'm thinking it's hung up somewhere inside and unable to push inward.
'76 cb750K Wiseco 836|ape crank/head|Carillos|CR29s|Dyna 2k|Kerker
'74 Norton Commando Fastback w/belt and bells
Offline michrobi
« Reply #2 on: July 11, 2009, 05:58:30 PM »
I split the cases again and took the countershaft out, put it back in, and it's all the way in just fine. It even looked at me innocently and said "wut?". Cases are back together with a flush countershaft. No idea what the problem was.
-Mike
