Author Topic: 550 start switch assembly?  (Read 945 times)
Offline Beans
  • I play with grease every day.
  • 1975 cb550f
    • bean's place.
« on: July 11, 2009, 05:56:45 PM »
Ok did a search but no luck.  Im looking for a start stop switch for my 75 550f and was wondering will a start stop switch from a 74 fit my bike?   I found one cheap but want to know before buying it. also does anyone know where I can get a throttle tube and cables for my bike.
Keep it shinny side up.
Offline Beans
  • 1975 cb550f
    • bean's place.
Re: 550 start switch assembly?
« Reply #1 on: July 11, 2009, 06:24:29 PM »
bump.
« Reply #2 on: July 11, 2009, 06:32:23 PM »
If you are planing on switching the internal parts from one control to the other, then it should work out.  If you are planning to switch the entire control pod, you should know that the starter switch works differently between the two models, and there will be wiring issues.
You question was rather vague and I nearly didn't answer it at all because of that.
Check out the differences in the wiring diagram of each bike.
Offline Beans
  • 1975 cb550f
    • bean's place.
« Reply #3 on: July 12, 2009, 11:36:27 AM »
yea I just looked and looks like the wires are the same.
« Reply #4 on: July 12, 2009, 01:14:54 PM »
Better look again.  If you really have an F model, those bar controls have a very different wire layout from the early K models.
Honda shop manual is my reference.
Offline Beans
  • 1975 cb550f
    • bean's place.
« Reply #5 on: July 12, 2009, 02:25:41 PM »
well then im screwed I just bought one off ebay from a 74550 I totally thought it would work.
