Author Topic: 76 cb750 front caliper...  (Read 2810 times)
Offline cijiwij
« on: July 12, 2009, 07:11:28 PM »
Has anyone got a working front caliper that I can buy? It's a 76 cb750. I can't find rebuild kits anywhere.
Thanks...
« Last Edit: July 13, 2009, 01:37:51 PM by cijiwij »
Offline cijiwij
Re: Need 76 cb750 front caliper...
« Reply #2 on: July 12, 2009, 07:37:01 PM »
Isn't there one ring on each side of the piston?
Offline ev0lve
« Reply #3 on: July 12, 2009, 07:42:19 PM »
Not unless your calipers are radically different than mine  ;D
1 piston side and the other is static
Part #8
http://www.cmsnl.com/honda-cb750k6-four-usa_model14380/partslist/F08.html
Offline cijiwij
« Reply #4 on: July 13, 2009, 01:37:25 PM »
Thanks...can I wire brush the crud off of the parts ?
Offline ev0lve
Re: 76 cb750 front caliper...
« Reply #5 on: July 13, 2009, 01:49:04 PM »
Anything on the outside. On the inside and especially the groove the seal sits in be careful not to scratch it while getting it spotless. Check the piston for wear and pitting too as anything too big will let it weep, wear the seal prematurely or hang the piston up.
Good luck!
