Author Topic: Here it is...the clogged oil pump screen (pic)  (Read 19540 times)
Offline jhasewhite
  • my best vacation is your worst nightmare
Re: Here it is...the clogged oil pump screen (pic)
« Reply #25 on: July 13, 2009, 08:09:55 PM »
holy single overhead cam batman! was the oil filtering, or just going through the bypass port? I just ordered a sump gasket- yeesh!
slow and steady does nothing.
Offline dpender836
« Reply #26 on: July 13, 2009, 08:12:05 PM »
wow! how does that much $%*& get in a motor? was this motor left open and mice built a home, or was this set on the ground without the oil pan on it. Looks like metal bits in there, you may want to split the cases and inspect it
Offline Johnie
« Reply #27 on: July 13, 2009, 08:12:45 PM »
After looking at this pic I think I def. need to check out my screen, but how do I do that?  Oh yeah, I just changed the oil too.
You have to drop the oil pan and the screen is right there.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline 750goes
  • it will live
« Reply #28 on: July 13, 2009, 08:27:44 PM »
good thought - flush out the oil tank as well - that's easy to do.
Maybe a recommendation - take off the oil lines from the tank to the engine and give them a flush as well - only a 10 minute job - then you know they are clean for when you run some fresh oil..
still stunned by the amount of crap in there -
did you take any pictures of the sump as well ???
Offline GammaFlat
« Reply #29 on: July 13, 2009, 08:43:25 PM »
You know... that looks malicious.  Somebody was so angry, that they "fixed" the bike by dumping debris in the oil filler.
K6
K7
Suzuki GN400 - Ignition fixed!
03 KLR650 - Doesn't do anything very well but.. well.. does everything.
Offline BlackMax
« Reply #30 on: July 13, 2009, 08:56:49 PM »
Uh oh....here's where my knowledge of "hands on" and all things detail in nature make me look like a bufoon.   Where is the sump??  I cleaned the pump pickup screen, replaced the oil filter and put it back together with a nice new gasket.  I plan on changing the oil a few times (maybe 3) at 50, 100 and 250 mile intervals, including maybe running some solvent the first or maybe the first couple times (like marvel mystery or sea foam).   Beyond that, I didn't get too crazy.  I mean, if this didn't kill it, how could 1/1000 of this end up doing damage as I go forward?
At least that's the way I'm thinking.  Am I thinking wrong?  I just got done cutting a new gasket and bolting the pan back up :-\
« Last Edit: July 13, 2009, 09:11:42 PM by BlackMax »
1978 CB750SS, 4-1 Yoshi, Pods, 3-angle valve job, ported chambers, ported intake, 41a cam
Offline cb350twin
    • http://mail.google.com/a/sohc4.net/
« Reply #31 on: July 13, 2009, 10:38:59 PM »
Man, what did the old oil filter look like? and what dose the bike in general look like?
1975 CB 750 K5
1972 CB 350 Twin K4
1972 CB 500 Four K1
Offline Spanner 1
« Reply #32 on: July 13, 2009, 10:49:20 PM »
Deadliest Catch !... ......( or Whale Wars, take yer pick ). Or ask Mike Rowe from 'Dirtiest Jobs' WTF it is !!
Oh ,the white thing I betcha it's...yes, wait for it....... KREEM ( Tank Liner ).!
« Last Edit: July 13, 2009, 10:58:22 PM by Spanner 1 »
Offline BlackMax
« Reply #33 on: July 13, 2009, 11:01:09 PM »
Old filter was dirty, but no visible chunks or particles.  This sort of indicates that all the bad stuff was limited to the screen.
As for the bike itself....it's nice.  You'd never guess.
« Last Edit: July 13, 2009, 11:05:04 PM by BlackMax »
Offline Spanner 1
« Reply #34 on: July 13, 2009, 11:07:44 PM »
Did the PO have an EXW ( Ex Wife )...!
Offline cb350twin
« Reply #35 on: July 13, 2009, 11:08:34 PM »
Wow, it's making me think of dropping my pan to see whats inside.
Anyone know if I have too remove the stock pipes on a 75 CB 750 K5 to drop the pan?
1975 CB 750 K5
1972 CB 350 Twin K4
1972 CB 500 Four K1
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #36 on: July 13, 2009, 11:23:37 PM »
You could always crawl under and have a look. ;)
Someone needs to send  BlackMax with the worst photo ever........ an SOHC  T-shirt just for having the balls to post it!
WOW!
Offline 750goes
  • it will live
« Reply #37 on: July 14, 2009, 01:31:14 AM »
blackmax,
the sump is what you took off to get to your oil filter screen - that thing you just made a gasket for..
did it have a lot of sediment in it as well ??
I hope you gave it a good cleanout anyway before you bolted it back on..
If anything is heavier than the oil - it will usually settle to the bottom of the pan - namely bits of white glittery metal means it could be your bike guts fallling  to pieces - or bits of steel, or bits of clutch fibres..
I'm sure you would have looked at the sump pan before you put it back together ??
Offline Johnie
« Reply #38 on: July 14, 2009, 05:45:39 AM »
WOW!
If you have stock pipes you should be able to get the pan off without removing them.  That is the case on my KO & K1.  Yours should be about the same.
Oshkosh, WI  USA
Offline wrenchmuch
« Reply #39 on: July 14, 2009, 05:50:02 AM »
I think I'm gonna puke  :P
CB750K1
CB750K4
Offline Gordon
  • 750K1, 550K2
« Reply #40 on: July 14, 2009, 06:19:11 AM »
Just don't puke into your engine like this bike's PO obviously did. :-X
Offline Toxic
« Reply #41 on: July 14, 2009, 06:23:05 AM »
Being a sick and twisted sort of guy... I want to see more pics.
lets see the inside of the sump pan and what came out of the bottom of the oil tank.
There has got to be a ton of stuff in there.
Truely amazing.
Offline Alan F.
« Reply #42 on: July 14, 2009, 06:35:51 AM »
+1 on flushing out the oil tank and lines seperately, maybe chase out the lines with a soft wooden dowel too as something may be lodged in there blocking oil flow too.
I remember seeing a locking oil cap somewhere on the web...anyone?
Some good detergent oil like rotella might carry any residual crud to the filter or the pump screen so you can clean it out later... just a thought.
Or maybe you'd be better off running a very high quality oil filter, the kind that gets clogged within a thousand miles...
« Reply #43 on: July 14, 2009, 07:11:25 AM »
Man, that pix looks like someone hurled in the engine. Makes me feel like it, now, too.  :P
All that silicone seal makes me nervous: if a PO sealed the crankcases with that much of it, I would be concerned that the oil passages at the alternator end and the points end of the crankshaft may be blocked from too much of that stuff. Those passages are small and the sealant, if there is too much, can ooze into the passages when reassembling. Just a thought.
Crankcases should never be sealed with silicone sealant: it should always be the latex-based stuff that you can get at most bike shops. The latex stuff, if a bit of it gets into those oil passages, will dissolve and ooze through the bearings and out into the crankcase, pass back through the pump and get trapped in the filter (or tank) later, with little or no damage anywhere. Silicone will just block the passages...  :-\
Offline BlackMax
« Reply #44 on: July 14, 2009, 07:33:36 AM »
blackmax,
Oh, duh. sump=pan.    Yea, it had a reasonable amount of gunk, but not many chunks, mostly the usual sludge.  Yes, I cleaned it up.    I did not remove the pump itself.....maybe silly considering I was already there, but oh well.  I'm fairly comfortable that the insides will be sparkling after a few oil changes (50,100 and 250).
Offline bistromath
« Reply #45 on: July 14, 2009, 09:45:13 AM »
HM: Is Threebond, like 1194 for instance, latex-based?
'75 CB550F
Offline SOHC4ever
« Reply #46 on: July 14, 2009, 11:46:12 AM »
What tha!
THIS IS SUPPOSED TO BE A FAMILY FORUM! HOW DARE YOU POST SUCH FILTH!
Offline Johnie
« Reply #47 on: July 14, 2009, 02:13:22 PM »
blackmax,
What oil are you using...I think the stock prices are going up... ;D
Oshkosh, WI  USA
Offline BlackMax
« Reply #48 on: July 14, 2009, 05:53:02 PM »
To finish this up....I put everything back together  (with a few snags of course).  It runs fine, sounds good and the oil is recirculating into the tank.  I see no leaks yet; but, I am keeping a close eye on the oil filter housing. It is looking a little juicier than I expect.
Now all that's left is to swap out the oil a few times, and see where we go.  Should be ok though.
Thanks for all the help!!
Offline TheHun
« Reply #49 on: July 14, 2009, 06:55:37 PM »
wow...nasty now your making me want to check that on my bike...disgusting..nasty..yuck
1978 Honda CB750-K
CBR F3 Coils
Kerker 4.1 Header w/ turn down
Maxi-Dwell Ignition
Foam Air Filter Pods
Superbike bars
Starter Delete
CARB CLEANING/REBUILD: http://www.wix.com/TheHun/CarbCleaning-Site
Not Running to Running, doing the work yourself= Priceless
