Author Topic: Front fork rebuild tips?  (Read 1177 times)
Gearhead57
« on: July 13, 2009, 09:49:10 AM »
Looking to rebuild the front forks on my bike. Have it close to finishing and realized how spongy the front is. My guess is now fluid.
Never been into a fork before. Can anyone tell me a good place to find instructions on how to do it or maybe walk me through it?
Aside from new seals and fluid anything I should expect to need?
Offline B.O.X.N.I.F.E.
  • The Stumped
Re: Front fork rebuild tips?
« Reply #1 on: July 13, 2009, 10:05:12 AM »
Go here, get the manual for your bike:
http://forums.sohc4.net/index.php?topic=426.0
I just did mine, a couple hour job. Replace your seals, they're about 10$.
I'd watch out for stripping the 6mm allen head bolts at the bottom of the fork tubes, mine were crazy tight and rounded a little. Also, find something like a block of wood to keep the cap from rocketing into your face when you remove it - there is a spring under there.
Fork oil, 10 wt, is available at most cycle shops. You can use ATF if you can't find it.
1974 CB550
Forever West
Offline cafe2be
« Reply #2 on: July 13, 2009, 10:10:51 AM »
I am going to be doing the same process for mine as well. Going with a -1" fork tube and progressive springs. My shocks bottomed out and dented my front fender.  >:(
Gearhead57
« Reply #3 on: July 13, 2009, 10:43:43 AM »
I've got a manual saved on my computer.
Guess I'll check it out and dig in.
Offline Johnie
« Reply #4 on: July 13, 2009, 03:05:03 PM »
It would help a lot guys if you would post the year and bike you are talking about.  Below is a pic of the guts of my KO, but not sure if you will see exactly the same thing.  Depending on what you are doing to the bike you could consider polishing the lowers if you want...
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
