Author Topic: 1967 Honda S90 project.  (Read 57879 times)
Offline tomkimberly
Re: 1967 Honda S90 project.
« Reply #100 on: October 23, 2009, 05:33:18 AM »
Here is the front brake hub all cleaned up and ready for paint.
Tom
Offline hoodellyhoo
  • CB350F
« Reply #101 on: October 23, 2009, 08:23:39 AM »
Looking good! Keep up the great updates!
Offline tomkimberly
« Reply #102 on: October 23, 2009, 06:47:28 PM »
Here is the front hub all painted.
Tom
Offline tomkimberly
« Reply #103 on: October 23, 2009, 06:49:55 PM »
Front brake plate painted.
Tom
Offline tomkimberly
« Reply #104 on: October 23, 2009, 06:52:23 PM »
I cleaned up and did a mock assembly of the front and rear axles. I had a darned of a time laying out the rear one as the PO had it backwards!
Tom
Offline tomkimberly
« Reply #105 on: October 23, 2009, 06:54:56 PM »
Front fork caps all refinished.
Along with the front brake cam lever arm and special nut.
Tom
Offline tomkimberly
« Reply #106 on: October 23, 2009, 06:59:17 PM »
Carb intake all refinished. This was nasty when I started, much sanding, polishing, removal of years of lime build up. I worked on this for weeks of and on. I think it came out very good!
Tom
Offline tomkimberly
« Reply #107 on: October 24, 2009, 11:08:52 AM »
Let's move onto the throttle assembly and handle bars.
Before:
Offline tomkimberly
« Reply #108 on: October 24, 2009, 11:13:38 AM »
Before I forget, the ports in the handle bars.
This one is for the throttle cable.
The next two are for the switch wires.
And the switch wires come out here.
Offline tomkimberly
« Reply #109 on: October 24, 2009, 11:17:28 AM »
The throttle tube and bits cleaned up real nice. I'm going to use a silicon type lube here when I put it all back together.
Tom
Offline tomkimberly
« Reply #110 on: October 24, 2009, 11:19:15 AM »
Rear pegs all cleaned up!
Tom
Offline tomkimberly
« Reply #111 on: October 24, 2009, 11:21:50 AM »
I sure hope those of you who are following this are learning something.  :D
Doing the actual work and documenting it all seems like doing double duty.
Tom
Offline tomkimberly
« Reply #112 on: October 24, 2009, 08:42:36 PM »
The wheel bearings I ordered came in todays mail. Might as well install them!
First the prep work, remove the bearings for the packaging and chill them down in the freezer for at least 1 hour.
Select a socket that is just a little bit smaller in diameter than the bearing.
Heat the hub to about 175 - 200 deg F in your oven (make sure the wife is not at home or you just might get in trouble!
Sometimes the bearing just drops right in, other times you need to tap it in.
Offline tomkimberly
« Reply #113 on: October 24, 2009, 08:47:14 PM »
The previous post was the rear sprocket hub, here is the front and rear brake hubs.
Each of these get two bearings, one on each side.
Tom
Offline crazypj
  • I'm brill, me
« Reply #114 on: October 25, 2009, 01:44:33 PM »
you did fit the spacer tube between bearings? (its just that you dint mention it and it doesn't look like its in there)
PJ
Offline tomkimberly
« Reply #115 on: October 25, 2009, 03:24:03 PM »
Ha! Good eyes! Yes I did, the second time around, good thing I ordered extra bearings.
Tom
Offline tomkimberly
« Reply #116 on: October 26, 2009, 09:20:18 PM »
Does anyone have a left hand perch / switch assembly they would be willing to sale for a reasonable price?
Tom
Offline TomC
« Reply #117 on: October 29, 2009, 04:44:42 PM »
Hi Tom
     It might help if you were to mention exactly which one you need. There are a number of different ones listed in the Parts List. Which goes by frame number and country sold in. Not the year of the motorcycle.
          TomC in Ohio
Tom
« Last Edit: October 30, 2009, 03:08:50 PM by TomC »
TomC in Ohio
76 CB750 F1 Daily Rider
76 CB550 stalled project
76 CB400F Injured Reserve
Offline tomkimberly
« Reply #118 on: March 14, 2010, 08:48:24 PM »
Just an update to all who were following this thread, I have at last located the correct spokes for both the front and rear wheels and will start up this thread in a few weeks.
It also looks like I need to upgrade my picture hosting.......
Tom
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=un2lilu331mommdaackgptt8m5&/topic,60973.0.html
« Reply #119 on: March 15, 2010, 12:18:28 AM »
we are vating.. :D,,love to see small hondaes..komming back to live...
i hate all this v-w.... vords
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #120 on: December 07, 2010, 07:44:12 PM »
Bump bump bump   ;D  Is she finished?  I've been hunting for one of these.
859Bryan
« Reply #121 on: January 20, 2011, 02:52:33 PM »
Tom,
When you were searching for parts, how did you know what would fit and what wouldn't when buying the stuff from Asia?  I am having a difficult time finding the wiring harness.  I have a 69? S90  Frame # S90-478916.  Any help would be greatly appreciated.
Bryan
Offline tomkimberly
« Reply #122 on: January 20, 2011, 08:52:01 PM »
Sadly, not yet. I have run into some health issues and work on this project has come to a stop. I hope to be able to move forward by summer (provided my leg heals).
The remaining items are finding another carb body or carb assy and working out any wiring problems.
Tom
Offline tomkimberly
« Reply #123 on: January 20, 2011, 08:58:24 PM »
Tom,
Bryan
Best guess? Yes I did order the wrong part a few times (spokes for one). For the wire harness, the one I had was just a bits and pieces and the back of the key switch was missing. What I did was match up the wire harness to fit/match the key switch connector. I do plan on having to perform a little trouble shooting with the wiring however I do have on of those Vintage Connection kits to make it look all good.
Hopefully TomC will chime in and let you know what issues he has run into during his restores.
Tom
859Bryan
« Reply #124 on: January 22, 2011, 04:06:10 PM »
Thanks, I will post some pictures after I really get started.  It is just a bead blasted frame at this point.
