Author Topic: 1967 Honda S90 project.  (Read 57898 times)
Offline tomkimberly
Re: 1967 Honda S90 project.
« Reply #25 on: August 17, 2009, 06:43:40 PM »
I'm in need of a right side (clutch) cover. The orginal one has a broken cable mount and the one I bought off of Ebay is not correct, I think it fits the 1965 models only.
Here is the orginal:
Here is the one I bought, look at where the chop stick is pointing.
Anyone have one for sale?
Tom
Offline Ecosse
  • Member #4139
    • My 550 walk around video
« Reply #26 on: August 18, 2009, 07:41:33 PM »
chop stick. nice touch.  ;D
sorry i can't help you.
1974 CB550K
                                  Your 1%er name
Offline tomkimberly
« Reply #27 on: August 22, 2009, 11:33:44 AM »
Well I have located the right side cover. This is the place that had one.
Now, can you name the place, city, and state?
Tom
Offline tomkimberly
« Reply #28 on: August 28, 2009, 09:27:05 PM »
Putting the engine back together.
Here are the parts:
Offline tomkimberly
« Reply #29 on: August 28, 2009, 09:32:37 PM »
The piston was stuck real good so we ended up going 2nd oversized.
Here is the head assembly:
Offline tomkimberly
« Reply #30 on: August 28, 2009, 09:36:50 PM »
A quick view of the cam chain tensioner:
Offline tomkimberly
« Reply #31 on: August 28, 2009, 09:40:47 PM »
Time to install the piston and get ready to install the cylinder.
The hose clamp is to compress the rings during the cylinder installation.
Offline tomkimberly
« Reply #32 on: August 28, 2009, 09:44:03 PM »
Let's install the cylinder, don't forget to install the base gasket and rubber cam chain seals.
Offline tomkimberly
« Reply #33 on: August 28, 2009, 09:48:17 PM »
Install the cam chain guide.
Install the head gasket too!
Offline tomkimberly
« Reply #34 on: August 28, 2009, 09:53:38 PM »
Time to install the head. Make sure to not let the cam chain drop down into the cylinder!
Offline tomkimberly
« Reply #35 on: August 28, 2009, 09:57:40 PM »
Let's secure the head, install the four copper washers and use new nuts!
Offline tomkimberly
« Reply #36 on: August 28, 2009, 10:02:34 PM »
Time for the cam, we need to line up the timing marks on the flywheel and the cam sprocket. Look where the chop stick is pointing, there are samll "O" marks.
Offline tomkimberly
« Reply #37 on: August 28, 2009, 10:06:52 PM »
One more item with the cam, there is a small dowel pin for driving the spark advance, remove it before you install the cam, you will need to re-install it after you install the cover/seal so don't lose it!
Offline tomkimberly
« Reply #38 on: August 28, 2009, 10:11:31 PM »
Time to align the cam timing marks and install the cam. Make sure the valve adjustment screwws are backed out (loose) as it makes installing the cam easier.
There is also another timing mark on the head as shown here.
Offline tomkimberly
« Reply #39 on: August 28, 2009, 10:14:17 PM »
Install the cam and secure using two bolts, also use a drop of blue loctite as no lock washers are used.
Offline tomkimberly
« Reply #40 on: August 28, 2009, 10:18:38 PM »
Time to set the valve gaps. The spec is .002" for both the exhaust and intake, as I like mine loose, I set them to .0025".
Offline tomkimberly
« Reply #41 on: August 28, 2009, 10:21:19 PM »
Lastly, let's install the cam cover/seal. Make sure to install the dowel pin afterwards!
Tom
Offline tomkimberly
« Reply #42 on: August 28, 2009, 11:22:15 PM »
On to the magneto. Notice the bad solder joints? Did I mention I hate PO's? Who ever did this should be shot!
Offline tomkimberly
« Reply #43 on: August 28, 2009, 11:25:06 PM »
Trim the wires, strip, tin, and solder, don't forget the shrink sleeving.
Offline tomkimberly
« Reply #44 on: August 28, 2009, 11:30:07 PM »
Let's install now!
Don't forget to install the netural switch cover!
Offline tomkimberly
« Reply #45 on: August 28, 2009, 11:32:48 PM »
Time to button up the left side of the engine.
Tom
Offline Ecosse
  • Member #4139
« Reply #46 on: August 28, 2009, 11:43:35 PM »
fantastic update!
1974 CB550K
                                  Your 1%er name
Offline kirkn
« Reply #47 on: August 29, 2009, 05:58:06 AM »
Outstanding!  Great update.  Keep up the good work, and keep the photos coming!
Offline tomkimberly
« Reply #48 on: August 29, 2009, 12:28:32 PM »
Here is the answer to my previous question, where is this place.
It's Ed's Honda Repair in Bakersfield, CA. Ed has a neet old time shop. They only work on old Honda's. The shop is busy enough to employee three full time mechanics. To the guys in the area, it is worth a stop to go and visit.
Offline Dougy Dougy Dune Buggy
  • Wrenchin Mofo
« Reply #49 on: September 01, 2009, 10:11:48 PM »
Yes..NOW that's what i'm talking about!  Awesome play by play..i'm following this one once in a while and this new update is so informative
Thanks Tom..i've been toying with a bore job and it's nice to see your progress as it fuels others' ideas..freakin AWESOME
Doug
I'm going to Cafe it
ONE DAY
ha ha
