Author Topic: CB650C plug boots with or without resistors?  (Read 877 times)
SpAmSoNiTe
« on: July 14, 2009, 06:43:57 PM »
Got what I hope will be an easy question :)
Had an original plug boot that cracked and started grounding on the case, so time to put on a new one...  Do the CB650's use resistor or non-resistor boots?  not that they're expensive, but I do have a couple of  new NGK hard shell 5k resistor boots hanging around.. can I use 'em?
        Thanks,
                  Sam.
Offline tomkimberly
Re: CB650C plug boots with or without resistors?
« Reply #1 on: July 14, 2009, 09:42:47 PM »
Resistor plug caps, yes, resistor plugs, no.
So the answer is yes, you can use what you have.
Tom
