Author Topic: NZ CB500 Bobber build  (Read 24520 times)
Offline Hush
Re: NZ CB500 Bobber build
« Reply #25 on: December 11, 2009, 04:06:08 PM »
Bike is coming along nicely, hey slow works for me...takes me at least 2 years before I can say I have "finished" a bike.
What's the chances of getting it road legal when you are ready to ride it?
Offline kwaggs27
« Reply #26 on: March 16, 2010, 04:54:08 PM »
What is the rear fender your using off of? Its a perfect fit and looks great!
1971 CB500
Offline fevah
« Reply #27 on: March 25, 2010, 07:33:13 PM »
Its a custom fibreglass one a guy in NZ on a bobber forum makes.
www.rattlers.co.nz if you want to him him up about making one.
Offline kwaggs27
« Reply #28 on: March 26, 2010, 02:54:46 PM »
Thanks for the website. Can I ask what battery your using on the swingarm? Isnt that alot of rockin and rollin bouncing up and down on the swingarm? Can it take that much shock? I want to move mine in the same location because I Konged my frame and dont really have a good location to mount the battery so that will be perfect.
1971 CB500
Offline fevah
« Reply #29 on: March 26, 2010, 11:51:40 PM »
Battery thats there is a stock looking thing, its toast anyway, wont hold charge for long.  Im gona grab a gel style one so should be a lot better.  I figure if its strapped firmly so it cant bounce then it should be all good anyway
I havent ridden it much as is.  I need a welder, sux having to rely on or ask friends that dont live nearby to do things for me
KaiDog
« Reply #30 on: April 02, 2010, 04:22:01 PM »
That does look good.  Have you considered any engine modifications?  I am in a project with a cb500 as well and I am not sure about the modifications I want to make (cam swap to a 650 cam and a 555 bore).  Did you have a thought process on making a decision to mod or not mod the engine? I just joined this forum.  This is my cherry post so be gentle.
Offline fevah
« Reply #31 on: May 04, 2010, 01:18:46 PM »
Been a while so thought id update. Camera batteries were flat tho and my cell doesnt like the dark garage. Will get better pics soon.
Anyway mate of mine welded up some exhaust tube for me to hold my electrics.  Cut it in half with a hole in the centre for the wires to feed.  The back is hinged and 2 bolts welded to the top hold it to a bracket between the frame.
Also made up a seat pan as the solo seat didnt look right between the wide frame.  Capped off the rear of the frame that was also cut off.
Offline fevah
« Reply #32 on: May 09, 2010, 12:56:28 PM »
Got bored and pulled out a rattle can and did the fenders last night.  Gloss was all i had instead of the satin it will end up being.
I cant stand the stock gauges but need to save up some cash to get a Vapor.
Offline Hush
« Reply #33 on: May 09, 2010, 02:59:14 PM »
Put the guages on Trade-me, you'll probably get enough for new ones and some decent paint. :D
Offline fevah
« Reply #34 on: October 16, 2010, 07:38:51 PM »
Been spending FAR too long doing the wiring on this.  Sheathed the looms in this weave thats used on computer cabling. all nice and tidy and easily removed and hidden.
LED warning lights in the headlight bucket and switch for the headlight on.  CBR250 Brake master and new brake hose
Vapor mounted and running
Ignition moved into the cover plate of the starter motor. Starter has been removed
Military style plug that allows removal of the electrics tube. has ignition and altenator wiring
Wiring placement
overview of wiring going into electrics tube
Main look plug, i'll replace this with military style one if i can find another
Made a new axle mounted plate mount, needs rounding but was a piece of scrap i had.
Electrics tube. kill toggle switch on the side
Tailight has 3 leds underneath for plate lighting
southernyank617
« Reply #35 on: October 16, 2010, 08:05:15 PM »
hey that turned out pretty nice. real similar to the 79 CB650 I built. (sorry no pics, camera didn't work and sold the bike) Great build, bobbed is the only way to go!
« Reply #36 on: October 16, 2010, 11:07:26 PM »
Any chance you could tell me where you got the headlight bucket from.? And what do you think of the Vapor dash..
Offline fevah
« Reply #37 on: October 16, 2010, 11:27:37 PM »
Pretty sure its just a chinese copy headlight.  Came on the bike.  Thinkn about taking to it with a scotchbrite. not down with chrome.
Vapor seems pretty sweet so far. i havent done much riding yet tho, its barely running on 2-3 cyl hence me ordering a new points.condensor baseplate setup. spark on the points for 2-3 is poor
Offline jacquesleclochard
  • If Tin Can do it, you can do it!
    • Tin Can Customs
« Reply #38 on: October 18, 2010, 09:23:59 AM »
So good. Dog seems to love the attention, too!
Offline fevah
« Reply #39 on: May 01, 2011, 02:29:58 PM »
Small update
Friend of mine made me up some Z bars and i got a vintage 6" headlamp for next to nothing off trademe.  Currently have no front indicators, will sort that at some stage.
Small update
Offline Hush
« Reply #40 on: May 08, 2011, 12:36:54 AM »
Look'n good Feva, I haven't seen "Z" bars since the 70's! Bike is looking real good though. :)
