Author Topic: Ignition Issues: Out of Ideas  (Read 6488 times)
Findlater
Re: Ignition Issues: Out of Ideas
« Reply #25 on: July 16, 2009, 11:43:31 AM »
That did help explain things and Im a little less frustrated however its a digital meter so knowing what setting to use is hard.  on the 2k setting I get the numbers above... which means open or closed on the point Im assuming there is a connection somewhere IE: a short or ground?  how would i find it?
Offline punch455
« Reply #26 on: July 16, 2009, 11:46:56 AM »
Did you disconnect the yellow lead completely?
'78 CB750F
Daytona Bars
Bar-end Mirrors
Custom Rearsets
Findlater
« Reply #27 on: July 16, 2009, 11:50:02 AM »
Yes open yellow lead to negative battery terminal and a test just grounding to engine and same numbers
Offline punch455
« Reply #28 on: July 16, 2009, 11:52:47 AM »
Ok this is good. But just to make sure, it was 47 to 52 OHMS right?  is there a "K" after that number?
'78 CB750F
Daytona Bars
Bar-end Mirrors
Custom Rearsets
Offline punch455
« Reply #29 on: July 16, 2009, 11:54:51 AM »
And is there a decimal point in there anywhere?
'78 CB750F
Daytona Bars
Bar-end Mirrors
Custom Rearsets
Findlater
« Reply #30 on: July 16, 2009, 12:10:10 PM »
that is the number on the 2k setting no decimal points and correct. If I move it down there would probably be a decimal lol
on the 200 scale of whatevere the f**k on this retarded digial readout that doesnt tell me much it was 5.2 ohms open or closed on the point
If I move it to 2000k it says its 052
« Last Edit: July 16, 2009, 12:16:08 PM by Findlater »
Offline punch455
« Reply #31 on: July 16, 2009, 12:20:32 PM »
Alright.  We now know that your 2-3 primary ignition lead has a short to ground. This is good news.  You just have to find it now.  Start checking that yellow wire up through the harness, making sure to look for any worn areas that are up against the bike frame.  The other end of that yellow wire plugs into the coil.
'78 CB750F
Daytona Bars
Bar-end Mirrors
Custom Rearsets
Offline mystic_1
  • 1970 CB750K
« Reply #32 on: July 16, 2009, 12:40:54 PM »
The points wiring runs out of the ignition case via a grommet and then runds under the engine along the right lower frame rail, up past the swingarm pivot to a set of connections near the rear brake switch.  There should be a rubber boot behind the frame rail, pull it up and access the blue and yellow wires there.  Disconnect the yellow wire at that point and repeat your test exactly as before, testing at the end of the wire in the points case.
Get the same results?  That means the short is between the points case and the harness connection.
Get different results (infinite resistance)?  That means the short is higher up in the harness.
mystic_1
- John Augustus Shedd
Findlater
« Reply #33 on: July 16, 2009, 12:44:23 PM »
thanks again guys I will do that quick test because on quick inspection of the harness there is no chafe or an apparent issues
at a 1 or 2 points the tape covering the wires has been removed or fallen off but the wires underneath look pristeen. I may just run a new cable to see if it solves the problem and leave the old one where it is. I'll post results soon
Findlater
« Reply #34 on: July 16, 2009, 01:04:49 PM »
The problem is in the harness I decided instead of look for the problem I would disconnect that wire entirely and run a new wire- I connected to the points wire and straight to the coil- no spark. If you guess have anymore ideas I'll be freaking impressed.
Offline Kevin D
  • SE Michigan
« Reply #35 on: July 16, 2009, 01:28:58 PM »
You asked for a picture of how the washers and wires line up so here it is.
Heres a wiring diagram:
http://oldmanhonda.com/MC/wiring750K1.html
Findlater, I might come to Ontario and fix that thing if you will let me ride that #41
 :D :D :D :D :D :D
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Offline punch455
« Reply #36 on: July 16, 2009, 03:47:53 PM »
Is that picture right? Wow I've had my connections on opposite sides of the point all these years!
'78 CB750F
Daytona Bars
Bar-end Mirrors
Custom Rearsets
Offline tomsweb1
  • '78 CB750A
  • '78 CB750A
« Reply #37 on: July 16, 2009, 04:01:33 PM »
Looks to me like the yellow wire and the point spring are touching ground... no fibre washer between them and the plate... am I mistaken?
Present: 1978 CB750A, 1978 CB400A, 1983 Nighthawk 550, 1984 CM250C
Past: 1977 XL100, 1982 KZ1300
Offline BlackMax
« Reply #38 on: July 16, 2009, 05:14:38 PM »
I read through the post, but I didn't see how you know there's no spark at 2 and 3. In other words, how'd you test for spark?  It sounds dumb, but I just went through the exact same thing (dealing with 1 and 4). I polished and gapped the points, tested the coils (fine)...still no spark.   When I tested the bare wires, there was spark.  My solution was to really really clean the offending plugs.  Sure enough, it fired up like a champ.    Now, I need to figure why the plugs fouled out in the first place....since it'll come back.
Kinda dumb, but wanted to throw it out there :-\
1978 CB750SS, 4-1 Yoshi, Pods, 3-angle valve job, ported chambers, ported intake, 41a cam
Offline mystic_1
  • 1970 CB750K
« Reply #39 on: July 16, 2009, 07:36:58 PM »
Post about the point plate insulating washers:
http://forums.sohc4.net/index.php?topic=51134.msg543537#msg543537
mystic_1
