Support the site. Your contributions keep this site running.
The K0 Tach had the redline at 8500 RPM, the lens was made from clear plastic and the gauge face was a greenish color, if I remember right. The later tachs had the redline at 8000 RPM, glass lenses (if brake fluid got on the plastic it would destroy it) and the gauge faces were changed to flat black to avoid glare.
There in lies the problem. I've seen a couple "sandcast" tachs on e-bay recently going for even more than you sold yours for. Thats why I was asking about K1 and K2 tachs. I will probably swap my K0 instruments for a K1 or K2 and put the originals in a box somewhere until I can find the parts I need. My K0 is a rider so putting the original parts in a box is probably better anyway come resale day (should that day ever arrive).
The only difference is in the head where the throttle or tach cable attach. Diecast KO is smooth and has a visable seam. Sandcast are rough with no seam. Sandcast heads were used later than sandcast cases. Early diecast 750s can have these sandcast parts at the speedo ,tach and front wheel.
we found a way to totally eliminate old anodizing to get a better finish when parts are redone.
