Author Topic: Oh. So you've got a problem with the BLACK plugs?  (Read 1017 times)
Offline SOHC4ever
« on: July 17, 2009, 09:56:55 AM »
Bike is a 76 750F w/ a K3 motor, and BOY is it ever producing a pitiful spark.
I'm running the stock coils, points, and new DR8EA plugs. Now, I understand that these are colder plugs with a resister in them. I only run them because they were in the bike when I got it.
I'm running the stock carb settings, stock exhaust. I haven't done a proper plug chop, but whenever I pull them they're way too black.
The bike is properly timed, valves adjusted to spec. I'm thinking of switching to D7EA plugs and seeing how that goes before I start changing the needle positions. Thoughts? Any other 750 guys want to chime in on their plug choice for stock bikes?
The bike lives at sea level, in case that makes a difference.
Offline Gordon
  • 750K1, 550K2
Re: Oh. So you've got a problem with the BLACK plugs?
« Reply #1 on: July 17, 2009, 10:02:49 AM »
Put in some new, non-resistor plugs and see what difference that makes before thinking about making other possibly unnecessary changes.
Offline ev0lve
« Reply #2 on: July 17, 2009, 10:03:08 AM »
Same boat. Same question  ;D
Good tune, synced carbs, 1 1/4 turns on the air screws...
There was some talk of widening the gap (assuming you don't actually have pitiful spark) so as to get more burn with the D8EA's but if you decide to throw some 7s in there please report your results.
I'm coming up on my 1500 mile oil change sometime in August and I'll give the wider gap a shot then I think  ;D
Offline Cvillechopper
  • Is just pretending to be an
  • If not for my failures I'd never know my limits
« Reply #3 on: July 17, 2009, 10:03:29 AM »
You need D8EA, not DR8EA.  You've got extra resistance in your current set-up.
It is the mark of an educated mind to be able to entertain a thought without accepting it.  Aristotle
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
« Reply #4 on: July 17, 2009, 10:09:41 AM »
You need d8ea. You are running resistor plugs. Hnce your poor spark.
/edit: beat me to it.
No.
Offline mystic_1
  • 1970 CB750K
« Reply #5 on: July 17, 2009, 01:52:38 PM »
This message is a message brought to you by the Department of Redundancy Department.
mystic_mystic_1_1
- John Augustus Shedd
Offline hapakev
  • Your Standard
« Reply #6 on: July 17, 2009, 05:50:01 PM »
 :D LOLing.....Too Funny :D
You Got Me  ::)
Smoking Jack
1978 CB750F(ish)
