Author Topic: 750F thread?  (Read 169046 times)
Offline david 750f
  • 1976 CB750F
Re: 750F thread?
« Reply #300 on: May 20, 2010, 01:32:58 AM »
Nice yellow 750F!! Any chance you could post a video so I could listen to the Motad exhaust?
1976 CB 750F
Offline theriddler
  • 1976 CB750F1
Re: 750F thread?
« Reply #301 on: May 20, 2010, 02:07:35 AM »
Will do.. maybe a week or so... :)
Offline theriddler
  • 1976 CB750F1
Re: 750F thread?
« Reply #302 on: May 20, 2010, 02:20:32 AM »
U.K. Motorcycle Silencers - Exhaust Systems:  Beowulf Exhausts are hand made in their shop in Halifax, West Yorkshire!  |  Chain Reaction motorcycle exhausts are some of the coolest looking out there for your Triumph! |  Motad Exhausts makes high-quality, road legal exhausts; they claim that the pipes fit properly, with access to oil filters and drain plugs  |  Predator exhaust systems makes silencers for Aprilia, BMW, Ducati, Gilera, Honda, Triumph and more
The above is copied from website:
http://www.webbikeworld.com/motorcycle-exhaust-systems/
My comments: they do seem to fit properly...does have access to oil filter... & from meory, the drain plug is accessible. Chrome quality really good. Searching on web - they seem to use a certain ammount of S/S parts, but don't think the whole system is. I think CB750F1 cost is around £250 to £300??
Re: 750F thread?
« Reply #303 on: May 20, 2010, 10:27:33 AM »
Who's going to take their F to the Corbin plant for manufacture of their Gunfighter seat? They'll keep it for a while and you can leave with a loaner. See the other thread.
Offline theriddler
  • 1976 CB750F1
Re: 750F thread?
« Reply #304 on: May 21, 2010, 05:55:14 AM »
Hi again,
Just doing some finishing touches to polished aluminium tappet cover and tranny side cover & chain guard...
Any suggestions as to how to seal the aluminium surface to stop it going dull?
lukepagel
Re: 750F thread?
« Reply #305 on: May 21, 2010, 07:34:48 PM »
Owned this '78 cb750f for about 6years. I only put about 1000miles on it a summer.
New top end all broke in and looking to do a new seat,
I want to use an old tank section so that the tank and the bump match.
Just gotta figure out how to put it together.  I might weld it to another seat pan I have.
I do have some small oil seepage at the head gasket by #1cylinder.  Not to bad but kinda dissapointing.
New spitfires. Brake pads. fluids. And polish.  Stock exhaust is sliced off and I drove a 3/4" stake thru it.  Also rejetted from stock 105 to 115. Synched and waiting for some dry weather(no front fender). I love this bike!!!!!
Offline Alan F.
Re: 750F thread?
« Reply #306 on: May 22, 2010, 10:23:39 AM »
I like it! Can we get some better pictures of your side covers. I was about to make some aluminum covers, but was going on imagination in terms of how they might look.
Yeah I second that, Alan F makes aluminum side covers and needed measurements for a F. I am going to do the measurements, but if you made yours made you could share your measurements with Alan F.
Thanks Gents, I actually spent an afternoon with Mick750F a little while back and I'm developing both a left and a right side cover that flow with the lines of the bike the same way the stock covers do, stay tuned.
-Alan F.
   Hey Alan...I don't remember if we discussed it but the left side covers for the F0/F1 are different than the F2/F3 as far as mounting goes...rights are the same. You should probably check out an early F to get the mounting right.
Mike
That's a good point there Mike, I wonder if anyone nearby has one?
Re: 750F thread?
« Reply #307 on: May 22, 2010, 10:30:08 AM »
Check with Mike Rieck
aaronjobe
Re: 750F thread?
« Reply #308 on: May 22, 2010, 12:02:30 PM »
New here! I have a 76f trying to decide now what color to paint it electric blue or pearl white.. I will post pics soon!!
Re: 750F thread?
« Reply #309 on: May 22, 2010, 06:46:25 PM »
Vlada: First, welcome and I wouldn't doubt if someone here can help you.
This is a SOHC4 forum and the SOHC models stopped in 1978. YOur 1982 is a Dual OVerhead Cam DOHC model.
It does look to me like a CB750F of the DOHC variety. However its had some add on parts like the fairing and the exhaust pipe which are not factory items.  But I'm no expert.
There is another forum here called "other bikes" and you might get some help there.
There is another site altogether for the DOHC models but I don't have the address.
Good luck.
vlada
Re: 750F thread?
« Reply #310 on: May 23, 2010, 02:21:21 AM »
Oh sorry,my bad,didn't know that about the engine,as you can see I am newbie...
MCRider thanks for help.
Edit: if it's in wrong topic feel free to delete it or move it...
Re: 750F thread?
« Reply #311 on: May 23, 2010, 10:53:33 AM »
Vlada,
You can also post your pictures directly to the site when you are posting. Above the emoticons/yellow faces where you found the hyperlink, click the one between You Tube and Insert Hyperlink. Copy and paste your link between the 2 img brackets.
vlada
Re: 750F thread?
« Reply #312 on: May 24, 2010, 11:03:56 AM »
Thanks Jerry,have done the modifications on the post.
Offline nobody
Re: 750F thread?
« Reply #313 on: May 27, 2010, 09:40:41 AM »
Pretty nice bike you've got there, Vlada. I like it.
74 cb750k
Re: 750F thread?
« Reply #314 on: May 27, 2010, 12:00:03 PM »
OK all you 750-F'ers!   :P
i've been enamored with the shape and style of the K's, and have had more than one snaked from under me in shady CL deals.  :'(
WELL, I ran across a very sad F2, no title(no worries), and in need of some serious love and attention.
heading out to pick it up int he am.  20k mi @ $500.
Need some tip / advice on the top 5 things i need to check on this bike before loading it.
The top 5 items that if buggered/broken/missing...etc, will cause me the most headaches/$/time. this one is close enough to stock, that i will fix it up stock. PO says it turns over.
thanks for helping a brother out!
FB1
Re: 750F thread?
« Reply #315 on: May 27, 2010, 12:06:42 PM »
FB1
rAISE MY SUSPICIONS:
Behind the sprocket cover is the case broken and patched with goo?
Is the rear tire bald, clue of abuse,
does it have oil and or gas in it? clue it may have been run dry,
others?
Offline spill
Re: 750F thread?
« Reply #316 on: May 27, 2010, 12:27:55 PM »
FB1
Compression test. Just do it cold.
\CB750F2
Words do not explain thoughts very well . . . but a picture might help!
Offline oldhondarider
  • http://indimediaimages-shepdog.blogspot.com/
Re: 750F thread?
« Reply #317 on: May 27, 2010, 02:21:48 PM »
FB1
" no title but that isn't a problem with the Internet title companies that are out there. Run the VIN with the Washington State Patrol if you want to verify there is no problem: CB750F-2104037"   Everybody is aware of the "INTERNET" title companies....but nobody uses them before the sell the bike...
He's in Seattle, you're in Snohomish... not too far away...   I saw it as well... but I have 3 750's cryin for attention already...  ;D    If you have him down to $500.00.... that doesn't seem bad...
dual front brake... hmmmmmmmm   ;D  if you want to part it out....I'd take the front end off your hands...
"I have never seen a wild thing feel sorry for itself. A little bird will fall dead, frozen from a bough, without ever having felt sorry for itself."   D. H. Lawrence
Welsh Customs, Tacoma Washington
Re: 750F thread?
« Reply #318 on: May 28, 2010, 06:39:16 AM »
hmmmm...possibly.    ;)
let me get this one home first and go thru it to see what it all needs.
btw...what other 750's you got hidin' at your place that need a different home?  ;D :P
Offline theriddler
  • 1976 CB750F1
Re: 750F thread?
« Reply #319 on: June 09, 2010, 04:06:37 AM »
My bikes now running! But the clutch is stuck - bit more work to do before MOT...I was going to post a video for sound of my Motad 4-1 (somebody wanted hear what it was like??), but it seems I can't? Anyway it won't prove much as the exhaust is very quiet. Idling a bit rough  - maybe still a bit cold but more likely carb synchronisation.
Offline theriddler
  • 1976 CB750F1
Re: 750F thread?
« Reply #320 on: June 09, 2010, 09:29:49 AM »
Heres youtube link to short video clip...
Offline Flying J
Re: 750F thread?
« Reply #321 on: June 09, 2010, 01:25:04 PM »
selling some comstar caps if anybody is intrested
http://forums.sohc4.net/index.php?topic=72171.0
Offline laser145
  • underfunded
Re: 750F thread?
« Reply #322 on: June 17, 2010, 07:01:07 AM »
Just picked up my first F, 1975, running condition. I haven't taken possession yet but once I do I'll get more pics up.
ktnexile
Re: 750F thread?
« Reply #323 on: July 05, 2010, 11:56:50 AM »
Hi again,
hello, did you receive any suggestions on this issue?
thanks
Re: 750F thread?
« Reply #324 on: July 05, 2010, 12:31:15 PM »
Hi again,
thanks
The factory finish is a clear lacquer coating. Over time this yellows and comes off in bits. Once this is removed to up-polish the part, you have the choice to go naked or re-spray a clear lacquer. many such products at auto and finish stores.
Unless you expect the bike will be in harsh environment with little chance for attention, I prefer to go naked and not deal with the lacquer degrading again as it will over time. Just repolish the covers occasionally with semichrome or such.
My personal prefrence, I'm sure some here prefer to spray some clear.
