Author Topic: 750F thread?  (Read 167807 times)
Offline cobrajunkie
Re: 750F thread?
« Reply #600 on: March 25, 2011, 04:58:27 PM »
Plates on the front.... bummer.  Very cool Zs in the movie.
Re: 750F thread?
« Reply #601 on: March 25, 2011, 05:03:09 PM »
No front plates now mate, that pic is early 70's
Offline Really?
Re: 750F thread?
« Reply #602 on: March 27, 2011, 08:47:53 AM »
Looks like one good pull of the front brake and it's medieval times all over again
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline turkey4me
  • The closer you are the less you can see!
Re: 750F thread?
« Reply #603 on: March 27, 2011, 10:17:25 AM »
Anyone out there with a 78 750F that can take a photo of the primary gear.  Mine is getting shredded by the chain and I think it is too far out on the shaft?  I can't however manage to move it from the present position.  Will try and post a photo of what I am talking about.
Offline maxspeed140
Re: 750F thread?
« Reply #604 on: March 27, 2011, 12:11:34 PM »
Hopefully this helps
Offline brandEn
Re: 750F thread?
« Reply #605 on: March 27, 2011, 12:27:00 PM »
Here is a pic from my rebuild on my 78 F
Offline turkey4me
Re: 750F thread?
« Reply #606 on: March 27, 2011, 02:12:37 PM »
Update on the sprocket wear...
I removed the chain guard for a closer look and the inside of the rear wheel sprocket is severely worn.  This tells me the front is either too far out or the back sprocket is too far in.  Using a laser sighted straigt edge on the rear sprocket face, they are off 3/8".  Holy smokes!!!  I have to say there is no way the front can be off that much.  Has to be the rear.  I double checked the rear wheel adjusters and they are dead even.  Then it dawned on me this is not a factory set up.  The rear wheel is a drum brake comstar from a K model.  Not your typical F setup with a disc brake.  Anyone know if this might be the issue?  All I can think of doing at this point is to remove the rear sprocket and install 3/8" spacer to move the sprocket out.
Offline maxspeed140
Re: 750F thread?
« Reply #607 on: March 27, 2011, 02:33:16 PM »
Didn't know they even made a comstar with a drum. You should try getting ahold of member ALAN F. He makes spacers. He might know. Here is his info http://forums.sohc4.net/index.php?action=pm;sa=send;u=142
Let us know how you make out with this.
Offline brandEn
Re: 750F thread?
« Reply #608 on: March 27, 2011, 02:38:57 PM »
Yea, can you post pics of your setup?
Offline turkey4me
Re: 750F thread?
« Reply #609 on: March 27, 2011, 03:17:43 PM »
Thanks for the help
Tried to post some photos of the set up.
Offline Ryan6838
Re: 750F thread?
« Reply #610 on: March 27, 2011, 03:24:05 PM »
Its your sprocket carrier on the rear 77/78 would have a diff spacing then the earlier and later bikes.
1978 cb750k
Offline turkey4me
Re: 750F thread?
« Reply #611 on: March 27, 2011, 03:28:31 PM »
What exactly is a sprocket carrier?
Offline brandEn
Re: 750F thread?
« Reply #612 on: March 27, 2011, 03:29:44 PM »
I might be wrong but I think those Comstars are for the DOHC model. If so that is more than likely your problem.
Re: 750F thread?
« Reply #613 on: March 27, 2011, 03:57:46 PM »
3/8 is 10 mm and that is the difference between a K8 and a K1-6 sprocket carrier and hub......i would say you have the wrong model carrier as well.....
Offline Ryan6838
Re: 750F thread?
« Reply #614 on: March 27, 2011, 03:59:14 PM »
Yeah those are dohc wheels and the carrier is the thing the rear sprocket bolts to that slides into the rear wheel. Youll eather need different spacers for your rear wheel or you can use it as a reason to go back to rear disk  ;D
1978 cb750k
Re: 750F thread?
« Reply #615 on: March 27, 2011, 04:11:42 PM »
You actually need an earlier carrier and spacers.....
Offline turkey4me
Re: 750F thread?
« Reply #616 on: March 27, 2011, 04:16:49 PM »
Is this the correct part # for the carrier  41211-405-000
http://images.cmsnl.com/img/partslists/rear-wheel-77_bighu0052f3211_7830.gif
part 3 described as Plate, Sprkt,side
Re: 750F thread?
« Reply #617 on: March 27, 2011, 04:27:49 PM »
No, thats just a cover, 13 is the carrier. If you pull your back wheel off you will get it straight away...... ;)
Offline Ryan6838
Re: 750F thread?
« Reply #618 on: March 27, 2011, 04:32:37 PM »
Will the correct carrier fit that wheel? IDK id the 77/78 carrier will fit in a dohc wheel.
1978 cb750k
Offline turkey4me
Re: 750F thread?
« Reply #619 on: March 27, 2011, 04:35:01 PM »
Thanks for your help and patience.  I think the easiest solution is to look for some spacers or a stock disk set up...
Offline Ryan6838
Re: 750F thread?
« Reply #620 on: March 27, 2011, 04:53:45 PM »
Yeah id look for a stock disk. easiest way and better braking
1978 cb750k
Offline nowhere_fast
Re: 750F thread?
« Reply #621 on: March 29, 2011, 01:12:41 PM »
Thought i would post a somewhat before and after shot of my 76 750f.  First attempt at a build, pretty happy so far
I took this one about a week ago
Offline brandEn
Re: 750F thread?
« Reply #622 on: March 29, 2011, 04:51:03 PM »
Looks real good. I like the red rims and accents.
Offline gearhead ed
Re: 750F thread?
« Reply #623 on: March 30, 2011, 09:56:43 AM »
Has anyone modified a 1977/78 750f stock muffler? And if so what did you do to it?
1978 750f    1964 Chrysler 300
Offline Freaky1
Re: 750F thread?
« Reply #624 on: March 31, 2011, 09:13:31 AM »
Chopped mine off with a hacksaw, leaving not much more than a open pipe. It was loud but did it improve anything? I doubt it.
That which does not kill you leaves cool scabs which turn into awesome scars.
'77 CB750F Come on...were almost there!
