Author Topic: 750F thread?  (Read 186327 times)
Offline oldhondarider
  • http://indimediaimages-shepdog.blogspot.com/
Re: 750F thread?
« Reply #750 on: December 03, 2011, 08:24:49 AM »
heres my 77 cb750 with alot of changes
nice.
"I have never seen a wild thing feel sorry for itself. A little bird will fall dead, frozen from a bough, without ever having felt sorry for itself."   D. H. Lawrence
Welsh Customs, Tacoma Washington
Offline RSchaefer
Re: 750F thread?
« Reply #751 on: December 05, 2011, 06:54:47 AM »
My 75F I just double drilled disc'd it and made a new muffler. 8,300 miles
[/quote]
This is an awesome idea.  Here's my cb750F.  Bought in 2005 for $750.  It's been a long road, but she runs like a champ now, and looks a little better too.
Hey Don I was looking at the dual brake setup you have and you have the plastic rotor cover on the right side.  How did you do that?
'66 CB77, 305 Superhawk (Project Bike)
'72 CL 175, (Project Bike)
'75 CB750F (Project Bike, Complete)
'05 GL1800 ABS Black Cherry (Current Ride)
'87 GL1200 Wineberry Aspencade
'83 GL1100 Wineberry Aspencade
'76 GL1000 LTD
'75 GL1000 Turquoise
'69 Honda 750cc Gold
'67 Honda 305 Dream Black
'63 Honda S90 Black
'61 Honda 50 Red
GWRRA #000008
VJMC Member
Offline jonreb
Re: 750F thread?
« Reply #752 on: December 06, 2011, 02:51:05 PM »
Heres my '78.  Got it in October and put a couple hundred miles on it and have been slowly fixing her up.  Suppost to have an 836 kit and aftermarket cam but who knows.  I shortened the stock seat so it still hinges and found the '75 header in the local junkyard, I like it better and it was alot cheaper than an aftermarket piece.  Gonna make some clubman style bars for it and dunno what else.
1972 CB350F
1978 CB750F
Offline HonderCB
Re: 750F thread?
« Reply #753 on: January 04, 2012, 07:29:21 AM »
I bought my 77F last summer and when i got it it wouldnt idle without the choke, and wouldnt rev without turning the choke off.  With my limited knowledge i decided it was running lean.  What i did was pulled the carb bowls to have a look at how clean the jets were (just in case) and they were clean, then i turned the adjustment screws out a few turns to richen it up.  It idled and ran great for the rest of the summer.  (I also took off the crappy pods and put on a stock air box i had laying around)  Even though it runs good now, the idle screws are turned out much farther than stock and i know its not set correctly.  I assume i need to adjust the needle clip positions, but i just didnt have time to pull the carbs and mess with it back then.  Well, now i do.
While i have it apart i was wondering if i should up the jets to 120.  If memory serves me it has 110's in it right now.  Some fairly knowledgable 750 people have told me it would run better with 120 mains, and i figure if i have to take it apart anyway, now would be the time.
So, my question is, what jet size are people running in their F2/3's and where do you have the clips and idle screws set?  I have a stock air box and filter as well as stock HM410 exhaust without baffle.
77' CB750F
81' CB650C - SOLD
Offline Graydude
Re: 750F thread?
« Reply #754 on: January 04, 2012, 12:45:25 PM »
Not sure what you mean by the float clips but if you are referring to the float bowl I run 14mm gap, 110 mains and my idle screw is set at 1 3/4 turns out.  I also run the PAMCO electronic ignition and the bike starts faster than my car.  Smokes like hell due to internal reasons but man she starts fast!
Re: 750F thread?
« Reply #755 on: January 04, 2012, 03:20:37 PM »
On the right hand rotor fender, I cut the mount off of one and removed the entire mounting plate from another, then riveted the mount plate to the opposite side. It took an evening of head scratching, fitting and grinding. I had thought about inverting the forks to put the caliper weight under the forks but I like the appearance of it as is.
Offline b82ta
Re: 750F thread?
« Reply #756 on: January 05, 2012, 09:01:34 PM »
So I've been working on getting my Architecture portfolio together, and needed some new photos of my 750F for it.  I did a mini photo shoot in my garage.  Here's the results...
Offline HonderCB
Re: 750F thread?
« Reply #757 on: January 06, 2012, 08:29:28 AM »
Is it safe to assume you are storing your battery up under the rear seat cowl?  and if so do you mind telling me what battery you are running?  A friend is building a cafe bike and we were lookin for options.
thanks
77' CB750F
81' CB650C - SOLD
Offline Picasoo
Re: 750F thread?
« Reply #758 on: January 06, 2012, 10:46:47 AM »
Nice bike... Nice pics!!
'75 cb750F super sport
Re: 750F thread?
« Reply #759 on: January 06, 2012, 02:43:06 PM »
Nice pics mate, but where's your oil tank? Cheers, Terry. ;D
Re: 750F thread?
« Reply #760 on: January 06, 2012, 03:39:43 PM »
Nice Bike and beautiful pics, how did you do the backdrop?
Offline b82ta
Re: 750F thread?
« Reply #761 on: January 07, 2012, 12:16:21 AM »
Thanks for the compliments all!
Terry- the oil tank is tucked into the frame just behind the airbox.  it runs parallel to the rails.  It was really a pain to make it all work...
Don- the backdrop is just a white sheet hung about 10 inches behind the bike, I lit both the sheet and the bike.
Re: 750F thread?
« Reply #762 on: January 07, 2012, 12:36:39 AM »
Thanks mate, on closer inspection I saw it, well done, it looks great! Cheers, Terry. ;D
maduncle
Re: 750F thread?
« Reply #763 on: January 07, 2012, 01:21:42 AM »
That oil tank might have been a pain - but it is the best alternative tank location I have seen on a CB750, well done.
Offline 78 k550
Re: 750F thread?
« Reply #764 on: January 07, 2012, 09:05:56 AM »
[/quote]
Like the Wing in the background also.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Re: 750F thread?
« Reply #765 on: January 07, 2012, 02:54:23 PM »
Thanks, the F and the 750 with the black tank are mine, the wing and the rest of the 750's are my brothers bikes and a couple of our parts bikes he saved over the years. Thank goodness for parts bikes.
Re: 750F thread?
« Reply #766 on: January 07, 2012, 03:38:07 PM »
Here you Go Cliff, here's another one....Its also a member's bike...
Offline fatmatt650
  • Part Deux
Re: 750F thread?
« Reply #767 on: January 07, 2012, 03:41:32 PM »
I actually started salivating when I saw that bike.
Re: 750F thread?
« Reply #768 on: January 07, 2012, 03:57:26 PM »
Can't remember who owns that one but there are some nice mods, including the oil tank, that impressed me.... ;)  The only thing i don't like is the Mac pipe....
Offline brandEn
Re: 750F thread?
« Reply #769 on: January 07, 2012, 04:10:29 PM »
That belongs to member deftone. Here is his build thread and website. All the pictures have been removed from the thread...
http://forums.sohc4.net/index.php?topic=30691.0
Analog Motorcycles
http://www.analogmotorcycles.com/
RD350 he built
http://www.bikeexif.com/yamaha-rd350-analog
Offline b82ta
Re: 750F thread?
« Reply #770 on: January 07, 2012, 07:17:29 PM »
That bike was precedent for my oil tank, its a very sharp bike.
Re: 750F thread?
« Reply #771 on: January 07, 2012, 11:01:46 PM »
+1 Mick, the bike is beautiful, but the pipe just looks cheap. Cheers, Terry. 'D
maduncle
Re: 750F thread?
« Reply #772 on: January 08, 2012, 02:01:48 AM »
Great bike - I like the Comstar paint treatment too.
Offline Freaky1
Re: 750F thread?
« Reply #773 on: January 09, 2012, 03:01:27 PM »
Some nice looking "F"s there!
That which does not kill you leaves cool scabs which turn into awesome scars.
'77 CB750F Come on...were almost there!
Offline Tree
  • CB750K5
Re: 750F thread?
« Reply #774 on: January 09, 2012, 09:10:02 PM »
My new to me F3.  Needs a lot of work  :)
